Subject Topic: Windows Scripting Host Post ReplyPost New Topic
Sparrow
Posted: November 05 2003 at 00:52 | IP Logged Quote Sparrow
Using a Global Variable that is null/empty, and maybe any variable (untested), as a parameter that is passed to the script function will cause an application error in powerhome and shut it down...
Back to Top View Sparrow's Profile Search for other posts by Sparrow Visit Sparrow's Homepage
Posted: November 11 2003 at 15:48 | IP Logged Quote dhoward
Todd,
I ran the exact test you've posted above without any problems.  I also checked the code and I already have it enclosed within try..catch blocks.
Could you try it again and post your results??  Are there any other differences that I may not be accounting for?
One possibility could be something to do with the {DIM} global variable.  The {D combination is an escape sequence used in ODBC calls and sometimes causes problems.  You might try changing the parameters field to: "{}{DIM}" and see if that makes a difference.
Let me know,
