         gg102 Senior Member
           | Posted: October 24 2020 at 15:04 | IP Logged
Hi Dave,
 It's good to be back with everyone.
 So far, I have been communicating with my Raspberry pi/s by dropping files on the pi/s and/or PH.  This mostly works, but it is quite clumsy and not very reliable.
 I am seeking a more reliable communication method.  So I thought to try socket comms.
 I have tried the following code to test:
 PH
  Formula:   ph_sendsocketdata('192.168.3.YYY', 8500,"Hello from PH_Server." )
 Raspberry Pi :
 #!/usr/bin/env python3
 import socket
 HOST =  '192.168.3.XXX' # Address of PH
 PORT =  8500   # Port of PH
  client   =   socket.socket(soc ket.AF_INET, socket.SOCK_STREAM)
 client.connect((HOST,PORT))
 from_server = client.recv(4096)
 client.send("I am Pi")
 print ("From Server: " + from_server)
 client.close()
 What happens with this test setup is that PH times out, and the pi crashes on client.recv(...).  I'm guessing that the socket never gets created, thus any attempt to comm will fail.
 I'd like to hear your thoughts.
 P.S. I think I fixed my private email address.
 gg
         gg102 Senior Member
           | Posted: December 14 2020 at 12:27 | IP Logged
 any thoughts on how to do socket comm?
           | Posted: December 16 2020 at 22:34 | IP Logged
gg,
 Im not completely up on Python on the Raspberry Pi but looking at the code you've pasted, it looks like you're trying to open socket client on
 the Pi when you probably need to open a socket server. The ph_sendsocketdata from PowerHome is a client socket that needs to connect to a
 socket that is listening for a connection.
 The Raspberry Pi code socket is also trying to connect to a server. Typically, I would expect you to open a socket and then do a "Listen" vs a
 connect.
