jostim Groupie
Posted: February 16 2007 at 05:02 | IP Logged
I am new with PH, so this could probably be programmed much more elegantly.
I have a few rooms in the house where I like to use an IR sensor, so the light turns on when someone enters. I use a few old Activehome PIR wireless sensors. They send an X10 signal that activates a macro that turns on the lights (via Icon dimmer switches). After a while the lights turn off again. When I use the switch to turn on the lights, the lights stay on.
I use PH version 1.03.4.9
You'll need the following Global Variables:
GRDRB_DIM_STEPS this is the number of steps the lights dim before they turn off.
GRDRB_ON_LEVEL the dim-level
GRDRB_SWITCH indicates if the switch has been used
GRDRB_TIME the time before the lights start to dim (multiply by 5 seconds)
GRDRB_TMP a temporary GV
there are four individual macro's (I said I was new at this)
the first one (GRDRB START) is triggered by the PIR sensor
insert into macroheader values ('GRDRB START','GARDEROBE LIGHTS',0,0,1);
insert into macrodetail values ('GRDRB START',1,10,'GRDRB_TMP',NULL,'{GRDRB_TIME}',0,'');
insert into macrodetail values ('GRDRB START',2,27,'',NULL,'if(ph_getglobal_s ("GRDRB_SWITCH") = "ON","END","CONT")',0,'');
insert into macrodetail values ('GRDRB START',3,26,'',NULL,'CONT',0,'');
insert into macrodetail values ('GRDRB START',4,27,'',NULL,'if(ph_getglobal_s ("GRDRB_TRIGGER") = "BUSY","END","MACRO")',0,'');
insert into macrodetail values ('GRDRB START',5,26,'',NULL,'MACRO',0,'');
insert into macrodetail values ('GRDRB START',6,1,'GRDRB TIMER',0,'',0,'');
insert into macrodetail values ('GRDRB START',7,26,'',NULL,'END',0,'');
the second one (GRDRB TIMER) is activated by GRDRB START
insert into macroheader values ('GRDRB TIMER','GARDEROBE LIGHTS',0,0,0);
insert into macrodetail values ('GRDRB TIMER',1,26,'',NULL,'START',0,'');
insert into macrodetail values ('GRDRB TIMER',2,27,'',NULL,'if(ph_getglobal_s ("GRDRB_SWITCH") = "ON","SWITCH","CONT1")',0,'');
insert into macrodetail values ('GRDRB TIMER',3,26,'',NULL,'CONT1',0,'');
insert into macrodetail values ('GRDRB TIMER',4,10,'GRDRB_TRIGGER',NULL,'"BUSY"',0,'');
insert into macrodetail values ('GRDRB TIMER',5,10,'GRDRB_TMP',NULL,'{GRDRB_TIME}',0,'');
insert into macrodetail values ('GRDRB TIMER',6,32,'GARDEROBE',17,'{GRDRB_ON_LEVEL}',0,'');
insert into macrodetail values ('GRDRB TIMER',7,26,'',NULL,'TIMER',0,'');
insert into macrodetail values ('GRDRB TIMER',8,31,'',NULL,'5',0,'');
insert into macrodetail values ('GRDRB TIMER',9,27,'',NULL,'if(ph_getglobal_s ("GRDRB_SWITCH") = "ON","SWITCH","CONT2")',0,'');
insert into macrodetail values ('GRDRB TIMER',10,26,'',NULL,'CONT2',0,'');
insert into macrodetail values ('GRDRB TIMER',11,15,'[LOCAL3]',NULL,'{GRDRB_TMP}-1',0,'');
insert into macrodetail values ('GRDRB TIMER',12,10,'GRDRB_TMP',NULL,'[LOCAL3]',0,'');
insert into macrodetail values ('GRDRB TIMER',13,27,'',NULL,'if(ph_getglobal_n("GRDRB_TMP")<=0," CONT3","TIMER")',0,'');
insert into macrodetail values ('GRDRB TIMER',14,26,'',NULL,'CONT3',0,'');
insert into macrodetail values ('GRDRB TIMER',15,15,'[LOCAL3]',NULL,'{GRDRB_DIM_STEPS}',0,'');
insert into macrodetail values ('GRDRB TIMER',16,27,'',NULL,'if(ph_getglobal_s ("GRDRB_SWITCH") = "ON","SWITCH","DIMMER")',0,'');
insert into macrodetail values ('GRDRB TIMER',17,26,'',NULL,'DIMMER',0,'');
insert into macrodetail values ('GRDRB TIMER',18,37,'',NULL,'***************DIMMER**************',0 ,'');
insert into macrodetail values ('GRDRB TIMER',19,31,'',NULL,'3',0,'');
insert into macrodetail values ('GRDRB TIMER',20,15,'[LOCAL4]',NULL,'[LOCAL3]-1',0,'');
insert into macrodetail values ('GRDRB TIMER',21,15,'[LOCAL3]',NULL,'[LOCAL4]',0,'');
insert into macrodetail values ('GRDRB TIMER',22,32,'GARDEROBE',22,'',0,'');
insert into macrodetail values ('GRDRB TIMER',23,32,'GARDEROBE',22,'',0,'');
insert into macrodetail values ('GRDRB TIMER',24,32,'GARDEROBE',22,'',0,'');
insert into macrodetail values ('GRDRB TIMER',25,32,'GARDEROBE',22,'',0,'');
insert into macrodetail values ('GRDRB TIMER',26,27,'',NULL,'if(ph_getglobal_s ("GRDRB_SWITCH") = "ON","SWITCH","CONT4")',0,'');
insert into macrodetail values ('GRDRB TIMER',27,26,'',NULL,'CONT4',0,'');
insert into macrodetail values ('GRDRB TIMER',28,27,'',NULL,'if(ph_getglobal_n("GRDRB_TMP")<=0," CONT5","START")',0,'');
insert into macrodetail values ('GRDRB TIMER',29,37,'',NULL,'ABOVE LINE IS FOR RESET OF TIMER BECAUSE OF RENEWED TRIGGER',0,'');
insert into macrodetail values ('GRDRB TIMER',30,26,'',NULL,'CONT5',0,'');
insert into macrodetail values ('GRDRB TIMER',31,27,'',NULL,'if(ph_getVAR_n(1,3)<=0,"CONT6","DIM MER")',0,'');
insert into macrodetail values ('GRDRB TIMER',32,26,'',NULL,'CONT6',0,'');
insert into macrodetail values ('GRDRB TIMER',33,32,'GARDEROBE',19,'',0,'');
insert into macrodetail values ('GRDRB TIMER',34,10,'GRDRB_TRIGGER',NULL,'"IDLE"',0,'');
insert into macrodetail values ('GRDRB TIMER',35,39,'',NULL,'',0,'');
insert into macrodetail values ('GRDRB TIMER',36,26,'',NULL,'SWITCH',0,'');
insert into macrodetail values ('GRDRB TIMER',37,32,'GARDEROBE',17,'{GRDRB_ON_LEVEL}',0,'');
insert into macrodetail values ('GRDRB TIMER',38,10,'GRDRB_TRIGGER',NULL,'"IDLE"',0,'');
this one (GRDRB SWITCH ON) is triggered by turning the switch on
insert into macroheader values ('GRDRB SWITCH ON','SWITCH ON',0,0,0);
insert into macrodetail values ('GRDRB SWITCH ON',1,16,'',NULL,'if(ph_getglobal_s ("GRDRB_SWITCH") = "ON",99,1)',0,'');
insert into macrodetail values ('GRDRB SWITCH ON',2,32,'GARDEROBE',17,'{GRDRB_ON_LEVEL}',0,'');
insert into macrodetail values ('GRDRB SWITCH ON',3,10,'GRDRB_SWITCH',NULL,'"ON"',0,'');
insert into macrodetail values ('GRDRB SWITCH ON',4,10,'GRDRB_TRIGGER',NULL,'"IDLE"',0,'');
insert into macrodetail values ('GRDRB SWITCH ON',5,10,'GRDRB_TIMER',NULL,'{GRDRB_TIME_FIXED}',0,'');
and this one (GRDRB SWITCH OFF) is triggered by turning the switch off:
insert into macroheader values ('GRDRB SWITCH OFF','GARDEROBE SWITCH OFF',0,0,0);
insert into macrodetail values ('GRDRB SWITCH OFF',1,10,'GRDRB_SWITCH',NULL,'"OFF"',0,'');
insert into macrodetail values ('GRDRB SWITCH OFF',2,10,'GRDRB_TRIGGER',NULL,'"IDLE"',0,'');
hope it works for you.
__________________ - jos
