Subject Topic: Newbie: ?Buttons? Post ReplyPost New Topic
TerryKing
Posted: October 27 2002 at 11:57 | IP Logged Quote TerryKing
OK, I Don't Get It...
I have PH installed; seems OK.
I have 3 X10 devices declared. They are controlled OK from Palmpad and X10-status.
In Explorer- X10-Housecode-Unitcode I have two keys
inserted for each device (ON-OFF). They stay, over restart etc.
BUT: In Control Center, I see: NOTHING. Tried several
variations, read manual.. Obviously I'm missing some
basic concept here!
Manual sez: "When you declare buttons for the control center..." WHAT exactly does this mean??   Searched thru "button" and "Declare" and still stumped.
IsThere a simple walkthru of a basic setup, or tutorial for newbies online??
This application looks great. Wish I could get it off the ground...
Regards, Terry King ...On the Mediterranean in Carthage, Tunisia, North Africa
Back to Top View TerryKing's Profile Search for other posts by TerryKing Visit TerryKing's Homepage
Posted: October 27 2002 at 14:59 | IP Logged Quote dhoward
Terry,
No problem. it can be a little daunting at first.  If buttons aren't appearing in the Control Center, you probably need to declare some tabs.  In the PowerHome Explorer, there is a section called tabs.  This is the screen where you can define each of the tab screens for the Control Center.  Be sure that the tab order is greater than 0 or it won't be displayed.  Once you've declared some tabs, you can go to the X-10 Housecode screen and declare what tabs the buttons for that housecode will appear on.   Once that is done, you need to restart the Control Center.  If you've set the Control Center to be windowed, then just close the window and re-open it.  If the Control Center is set to be a background, you'll need to either restart PowerHome or Reinitialize under the File menu.  You should now see your tabs and the buttons.  Actually, the buttons will all be stacked one on top of another so it will appear to be a single button.  You'll then want to right-click on the tab you're interested in and go into design mode.  You'll get a  new design window with a new toolbar and you can arrange and size the buttons the way you like.  Save your changes and restart the Control Center window again.
You can also launch the sample database included with PowerHome.  To do this, shutdown PowerHome and edit the pwrhome.ini file in the PowerHome directory.  The line that reads DSN=PowerHome can be changed to DSN=PowerHome Sample.  Save the ini file and restart PowerHome.  You'll now be using the sample database and you can export macros, etc. that you find interesting to import into your database.  To get back to the blank database, just change the line back and restart.
Let me know if you have any other questions,
TerryKing
Posted: October 27 2002 at 16:08 | IP Logged Quote TerryKing
OK, Thanks!
I didn't understand the Tabs back in House Code.
I did finally find out that Macros Make Buttons Too.
Let me try out some more stuff; it's hard to know where to start!
Posted: October 27 2002 at 18:19 | IP Logged Quote dhoward
Also, infrared and Send Keys will make buttons as well.  The Send Keys is very useful as well as macros because they can appear on any tab.
