         mghan Newbie
           | Posted: May 07 2007 at 11:16 | IP Logged
I'm have an issue regarding the Insteon PLC setup and a search here turned up nothing.
 Using Explorer>Setup>Controllers>Settings, the Maximum Failures seeting always clears to 0 when I click Done.
 When using Insteon Explorer>Setup, I can set Max Failures, however it resets to 0 when I restart PowerHome.
 Mike
           | Posted: May 07 2007 at 21:34 | IP Logged
After you change the count, are you clicking on Save PLC Settings?
         mghan Newbie
           | Posted: May 08 2007 at 10:57 | IP Logged
Thanks for the response.
 Yes, I've clicked Save PLC Settings.  I can change the Poll Interval and it will stick, just not Max Failures.
 FYI  V1.03.4.10, prior version had the same issue as well.
  Edited by mghan - May 08 2007 at 10:58
  __________________ Mike
