patrickm Senior Member
Posted: May 29 2007 at 14:44 | IP Logged
Hello,
I would like to write a macro that would be able access a 2d array for the parameters i.e. device and duration. I am trying to avoid having to write very long macros with specific variables for each device and duration in the macro and just use a loop with a pointer to an array.
Posted: May 29 2007 at 20:54 | IP Logged
Arrays are only supported in scripts. Sounds like you may be able to handle that, though, since you mentioned "pointer".
Posted: May 30 2007 at 01:21 | IP Logged
Are the Insteon functions supported from within scripts directly? I didn't see any listed in the help file, but I believe the help file hasn't been fully updated yet.
Posted: May 30 2007 at 08:11 | IP Logged
I believe that you can use ph.formula( ph_insteon(xxx) ) for that.
eHomeCreations Groupie
Posted: June 04 2007 at 02:38 | IP Logged
Arrays are tables. Can you just create a table and use that?
__________________ --Steve http://www. ehomecreations.com
Posted: June 05 2007 at 12:38 | IP Logged
I searched for tables in the help file and didn't see any references. A table would work if they exist.
Posted: June 05 2007 at 19:54 | IP Logged
There is a User Table (UserData1) that you can populate.
Posted: June 05 2007 at 23:48 | IP Logged
I assume that is accessed by sql commands?
Posted: June 06 2007 at 07:10 | IP Logged
Sorry! Yup.
