bhlonewolf Senior Member
Posted: June 22 2007 at 12:37 | IP Logged
Hi gurus,
I have a 2 buttons linked to some lights outside my garage. All works as expected.
I have an x-10 keychain remote that sends a command to powerhome to turn on the lights. A motion sensor does the same thing. It triggers a macro to turn on the light, wait 5 minutes, then turn it off. This works fine, too.
What I'd like to do is: if a user turns on or off the light manually (at either switch) I kill the waiting macro. I'm having a hard time differentiating between a user hitting the switch, or a second press of the keypad, etc. Is there a way to set up a trigger to listen for local control only?
