mustangcoupe Super User
Posted: July 06 2007 at 09:55 | IP Logged
I am looking to code this up and need to download the latest release tonight.... But I am going to ftp a image from my security cameras to a folder and I want to 1 up load these to another ftp site and 2 email them to my cell phone when the elk goes into alarm mode. but does anyone have a starting point for me? the files will be ftp'd to the computer running PH from the camera every minute there is motion
HA newbie
PowerHome - UPB - ELK
Posted: July 06 2007 at 13:26 | IP Logged
I guess you need to make sure that you can receive the image on your phone.
I have AT&T and have not found a way to do it, so I just save the image to a file in my ph web folder.
Posted: July 06 2007 at 15:45 | IP Logged
I don't believe it will be a problem... But I will check it tonight. But I am running windows mobile 5 on a ppc. And I can get email files, and documents no problems...
Edited by mustangcoupe - July 06 2007 at 15:46
HA newbie
Posted: July 06 2007 at 18:15 | IP Logged
Try ph_sendemailfile.
Posted: July 08 2007 at 09:15 | IP Logged
ph_sendemailfile("todd@thehannemannweb.us", "Basement Security Cam Photo", "Basement Security Cam Photo","C:\cameras\basement.jpeg")
I have tried with and without the quotes and it responds with an error in my formula.... As in the help menu it should have a 0 if OK or 1 if there is a email error.... I get an ! (formula error)
HA newbie
Posted: July 08 2007 at 10:06 | IP Logged
I am getting error 2. Email in macros works for me. Digging into it...
Posted: July 08 2007 at 10:11 | IP Logged
ok, DUH... I am VNC'd into my machine and I didnt notice the eamil setup window that popped up.... I needed to set up an emai acccount on the machine. BUT first it pops up a outlook express window asking if it is OK to send mail.... 2nd I never received it im my other email account nor did it get returned.
edit: ok got problem 1 solved... .
Edited by mustangcoupe - July 08 2007 at 10:15
HA newbie
Posted: July 08 2007 at 10:18 | IP Logged
OK, I just had a typo. After fixing that, it worked.
I just copied your formula and changed things to match my system.
Make sure you set up the email variables [DIALUPUSER] and [DIALUPPASSWORD].
Posted: July 08 2007 at 10:20 | IP Logged
I am now getting a 2 response... I'm almost there. Not on dial up so it should just send... (or do I still need to set these?)
HA newbie
Posted: July 08 2007 at 12:39 | IP Logged
Heh. Don't think about the dial-up part. Legacy verbiage, I guess!
My error 2 was the file path being incorrect.
Posted: July 08 2007 at 16:28 | IP Logged
hmm I tried it with the email user name and password but that still didn't send... Im getting error 2
HA newbie
Posted: July 08 2007 at 18:16 | IP Logged
Are you 100% sure that, "C:\cameras\basement.jpeg" is correct? Maybe .jpg instead?
Posted: July 08 2007 at 18:32 | IP Logged
that was it..... thanks Tony
Now I need to figure out how to check my Elk Status and play the macro on that... I just need more time to get it all working!
HA newbie
Posted: July 10 2007 at 11:33 | IP Logged
You may want to use ph_sendsmtpemailfile instead. This uses SMTP instead of MAPI and will eliminate the need for an email client or the possibility of the "Allow program to send email" type of message that pops up.
