         JustAnotherJoe Newbie
           | Posted: October 07 2007 at 21:09 | IP Logged
When tapping or double-tapping a SwitchLinc paddle or a KeypadLinc button, it sends group commands as opposed to direct commands, correct?  What gets sent when the paddle is held down to brighten or dim; is it Start Manual Change when pressed and Stop Manual Change when released, or is it a string of Bright/Dim commands like with X-10?  I ask because as far as I could tell, Start/Stop Change are direct commands only (not group), so how would that work with a linked group?
  __________________ Just Another Joe
           | Posted: October 15 2007 at 10:55 | IP Logged
Joe,
 You are correct.  Insteon does not send repeated bright/dim commands like X10 and instead sends a single "Start Manual Change" when the button is held followed by a single "Stop Manual Change" when the button is released.  These commands are sent as group broadcast commands and are not followed by group cleanup commands.
           | Posted: October 15 2007 at 19:54 | IP Logged
Thank you, Dave.  Just what I needed to know.
