kemaa Newbie
Posted: October 17 2007 at 18:46 | IP Logged
I am trying to import the GET WEATHER macro using the SQL commands. The directions I'm following seem clear enough but I'm not getting the same results. This is the text I'm running from (from http://www.diy-ha.com/infofrominternet.php)
"First, before reading any further, load Powerhome, go to the Multi Editor, set it to SQL, and paste in the contents of this file[see file below]. Then, create a Global Variable called CURTEMP
This will set up the basic structure that you need to grab data. It should create a macro called Test. Go into Powerhome Explorer and load this macro."
The file they had me download was:
"insert into macroheader values ('TEST','TEST',0,0,1);
insert into macrodetail values ('TEST',1,15,'[LOCAL1]',NULL,'ph_geturl( "mobile.wunderground.com/cgi-bin/findweather/getForecast?bra nd=mobile&query=19004")',0,'');
insert into macrodetail values ('TEST',2,15,'[LOCAL1]',NULL,'ph_readfile ( "C:\Program Files\powerhome\wum.htm" )',1,'');
insert into macrodetail values ('TEST',3,38,'',1,'ph_writefile ( "C:\Program Files\powerhome\wum.htm", 1, "[LOCAL1]" )',1,'');
insert into macrodetail values ('TEST',4,10,'CURTEMP',NULL,'ph_regexsnap(''<tr><td >Temperature</td>~255<b>\(.+\)</b>° ;F'',"[LOCAL1]",1,0)',0,''); "
I don't see any macro called TEST creating itself when I make the global variable CURTEMP. Can someone please help me with this? I'm sure it is a small error that I'm missing like not clicking apply or something like that.
Thank you.
Posted: October 17 2007 at 21:29 | IP Logged
Whose site is that?! At least they give me credit!
The TEST macro will appear when you paste in that text into the SQL editor and execute it.
kemaa Newbie
Posted: October 23 2007 at 16:05 | IP Logged
Thanks, I was able to get the macro to load. When I ran it I had nothing happen. I created the global variable CURTEMP and I see the wun.htm file (which is blank). Is there something else that I need to do to get this to work?
kemaa Newbie
Posted: November 01 2007 at 20:42 | IP Logged
From reading a little bit on the help menu it says that the geturl function uses the proxy server set up in Setup. I haven't changed this from its default settings. I don't opperate my machine on a proxy (that I know of). Would this have anything to do with my lack of data coming back?
Posted: November 01 2007 at 20:59 | IP Logged
No, if you don't have a proxy, you should be fine.
So, you now have the TEST macro if you click on Macros in the PH Explorer?
kemaa Newbie
Posted: November 02 2007 at 16:25 | IP Logged
Yes. When I select that macro from the Macro/Formula dropdown box and click run it creates the wun.htm file but it is blank and the value of CURTEMP is still blank.
jbbtex Senior Member
Posted: November 02 2007 at 17:33 | IP Logged
kemaa,
If the second line of the TEST macro is:
Set System [LOCAL1] ph_readfile ( "C:\Program Files\powerhome\wum.htm" )
Click the Skip box on that line and then run the macro. When I run it with that line skipped it works fine. If that line executes, wun.htm is blank.
__________________ Brady
Posted: November 02 2007 at 19:23 | IP Logged
Wow! That line was in there for testing. I guess I forgot to check Skip when I exported! Sorry!
Posted: November 02 2007 at 19:57 | IP Logged
It is checked on yours. The one he mentions above is here: http://www.diy-ha.com/GetWeatherSimplified.txt
It is skipped there too, but on the tutorial page they have a screen shot that doesn't show the Skip box. And this: "Lines 2-3 in the macro write a local file--you shouldn't have to bother editing this."
Posted: November 03 2007 at 09:12 | IP Logged
Ah, ok!
kemaa Newbie
Posted: November 03 2007 at 11:12 | IP Logged
I'm still having some problems but I'm narrowing down the cause. When I run formula checker on the formulas for each line, the formula evaluates to:
HTTP/1.1 400 Bad Request
Date: Sat, 03 Nov 2007 15:07:42 GMT
Server: Apache/1.3.33 (Unix) PHP/4.4.0
Connection: close
Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<HTML><HEAD>
<TITLE>400 Bad Request</TITLE>
</HEAD><BODY>
<H1>Bad Request</H1>
Your browser sent a request that this server could not understand.<P>
The request line contained invalid characters following the protocol string.<P>
<P>
<HR>
<ADDRESS>Apache/1.3.33 Server at l3a10.wunderground.com Port 80</ADDRESS>
</BODY></HTML>
I tried playing around with the address (adding a http:// at the front of the address just in case but still no luck. I'm certain that my problem is stemming from the lack of web page results. I can load the page no problem in my browser so I'm figuring something is wrong with the call.
Thank you for your help so far. If I can get this to work I'll definately start to run with this quickly.
Edited by kemaa - November 03 2007 at 11:15
Posted: November 03 2007 at 12:48 | IP Logged
You are using this?
ph_geturl( "mobile.wunderground.com/cgi-bin/findweather/getForecast?bra nd=mobile&query=ZIP")
kemaa Newbie
Posted: November 03 2007 at 15:35 | IP Logged
I've noticed that somehow spaces were inserted into the code from the import. I fixed two different pieces already. There was a break that I can see in your post as well. (brand=mobile not bra nd=mobile). I have been playing around with the formula for ph_regexsnap. I changed it because I couldn't find the ~255 anywhere in the returned text. This is now my formula:
ph_regexsnap('<tr><td>Temperature</td>
<td>
<span class="nowrap"><b>\(.+\)</b>°F,"[LOCAL1]",1,0)
This returns a ! into CURTEMP, which is a step in the right direction because I'm getting a return value finally. According to what I've been reading in the help file, I should have picked out the right portion of the string to grab.
Posted: November 03 2007 at 16:40 | IP Logged
Yup, the board here adds spaces frequently.
The ~255 is regex for "skip stuff". This is what it should be...
ph_regexsnap('<tr><td>Temperature</td>~255 <b>\(.+\)</b>°F'," [LOCAL1]",1,0)
Delete any spaces.
An "!" means that the formula has an error.
kemaa Newbie
Posted: November 03 2007 at 16:52 | IP Logged
Back to no return value. Do I need to include the & #176; (without the space) or just °. They seem to equal the same thing. I wrote it in my code as the first one but when I posted it online it was converted to the degree symbol. Does the search string need to look like the html code it is parsing through or can it be some of the visual results instead?
Posted: November 03 2007 at 18:47 | IP Logged
Dangit. The board changed the & #176; to a degree symbol. Yes, it should look just like the HTML code.
Browse to that page, view the source of the page, then search for that first section (<tr><td>Temperature</td>) and make sure it's even in there. Your ZIP may be getting different code.
kemaa Newbie
Posted: November 04 2007 at 17:27 | IP Logged
I finally got it to work. Thanks a bunch! I'll be playing around with this now that I know it can work for me.
