Subject Topic: KEEP ALIVE???? Post ReplyPost New Topic
bmeeke
Posted: December 06 2007 at 19:32 | IP Logged Quote bmeeke
I am getting a strange error message on my Log file:
Web Access
OPTIONS / HTTP/1.1
translate: f
User-Agent: Microsoft-WebDAV-MiniRedir/5.1.2600
Host: Hhnn101b
Content-Length: 0
Connection: Keep-Alive
Hhnn101B is the machine that is running Power-Home
This error pops up and repeats itself every minute.   Not sure what to think.... any suggestions?
Brian Meeke
Back to Top View bmeeke's Profile Search for other posts by bmeeke
mustangcoupe
Posted: December 07 2007 at 19:41 | IP Logged Quote mustangcoupe
what is at ip 192.168.1.104
it looks to be accessing your web interface....
Maybe full time?
Todd Hannemann
HA newbie
   PowerHome - UPB - ELK
Posted: December 08 2007 at 09:33 | IP Logged Quote BeachBum
I would guess you are trying to access your PH system from another system on your LAN and you don’t have 192.168.1.104 as a Trusted IP in Setup under WEB.
Posted: December 09 2007 at 12:01 | IP Logged Quote dhoward
The log entry isnt an error message per se. It's showing you that IP 192.168.1.104 is making a request against the PowerHome web server. It shows that you've got the webserver running (you can disable it if you don't want it).
If it's happening once a minute, it's possible that you've left the Device Status screen open on a web browser on 192.168.1.104 as this screen refreshes once a minute.
You could go into your webserver setup and add 192.168.1.* to your trusted IP's and then turn off logging for trusted IP access.
bmeeke
Posted: December 17 2007 at 21:06 | IP Logged Quote bmeeke
Thanks for the advice. I will investigate.
Brian Meeke
