| Posted: February 08 2003 at 21:21 | IP Logged
Ron,
When you register PowerHome, the registration info is contained within the database. Hopefully you made a backup after you registered because if you need to reinstall PowerHome, you just need to copy the backed up database over the newly installed one and all is well. If you didn't make a backup, just email me the new registration number from your new install and I'll email you the unlock key for it.
The registration number is based upon the registration name you enter along with some random numbers so every registration number is unique. The unlock key is tied to the unique reg number which is why it is failing on your new install. If you were to compare the reg number on your new install with the reg number on your old install, you will see that they are different even if you entered the same reg name.
Anyways, to make a long story short...just copy the database file (c:\program files\powerhome\pwrhome.db) from your old install to your new install. If you don't have your old database file, just email me your new reg number and I'll send you the appropriate unlock key.
Hope this clears things up ,
