Posted: March 03 2003 at 10:45 | IP Logged
Dean,
I am so sorry!!!!! I rely upon an email notification to let me know when messages have been posted to the board and Ive either missed it or did not get it. Usually I'll reply within 24 hours (sometimes longer over a weekend if Im out), so if you don't get an answer by then, feel free to post again or email me directly.
Since it's been so long, has any of the data changed? Your slow dim macro should work without a hitch. I'll give it a try myself when I get home tonight and verify.
The antenna on the MR26A makes a huge difference. However, I don't think it would contribute to your dimming problems if your PowerHome eventlog is showing the data being received properly.
If your analyzer is showing the X-10 being sent, then it probably is a hardware problem specific to the module. The only variable that Im not really familiar with is the repeater-amplifier. The ON and OFF commands are straightforward, but dimming is handled a little differently in that there is no gap between commands for repeated dims. If I remember correctly, some repeaters may have a problem with dims. You may want to do a check on dejanews for X-10 dimming through repeaters.
Let me know if any new info is available and sorry for taking so long to respond.
