ficklma1 Groupie
| Posted: May 01 2008 at 09:42 | IP Logged
Using the latest alpha version of PH, can I use the EZSrve in place of the PLM?
| Posted: May 06 2008 at 12:51 | IP Logged
Not that Im aware of. Unless it connects via a serial port and uses the same protocol as the PLM, it won't work.
I havent looked to closely at this device yet, but if I understand it correctly, it basically allows control over the Insteon network by connecting to it via ethernet.
I won't have it in time for the next beta, but I'll look into this device after the beta is out.
ficklma1 Groupie
| Posted: May 08 2008 at 17:32 | IP Logged
Thanks for the information, Dave.
I'm trying to determine my best route to replace my PLC.
I was originally thinking of getting the EZSrve, but I think a more flexible route would be to get the plain PLM now. Then later add the EZBridge (this combo I believe is technically the same as the EZSrve)
That way I can use the PLM with PH now and if I feel like using the PLM without a PC, I'll add the EZBridge or an ISY later.
Edited by ficklma1 - May 09 2008 at 13:17
