kenbr Newbie
Posted: July 14 2008 at 22:08 | IP Logged
is anyone running PH as a service? has anyone figured out how to get the console up when running as a service?
i'd really like to have PH come back up after a reboot, but i need to lock my computers (username/password) to protect my VPN. i don't think i can set PH to start automatically unless/until i login other than as a service. might be missing something here, but..
so how is everyone doing this?
thanks,
kenb
jeffw_00 Super User
Posted: July 15 2008 at 12:49 | IP Logged
use the scheduled tasks control panel to add it as a task that runs at startup, then open the advanced window and you can de-select "run only when I'm logged in" and give it your username and password and it should log itself in upon reboot.
let us know if it works
kenbr Newbie
Posted: July 15 2008 at 21:43 | IP Logged
thanks! i'll try this in the next day or two and report back.
kenb
kenbr Newbie
Posted: July 16 2008 at 19:51 | IP Logged
I've made the changes noted previously in this thread..
OK, Powerhome and the SDM start up automatically after a reboot and I can access PH by browsing to the localhost port 80 (I am able to turn lights on/off via the web server). But, if I start PH from my desktop so that I can access and change settings I get an error box every few seconds that tells me PH can't start the PLC. Of course, nothing shows in the SDM log window.
I assumed that by starting PH this way that it might behave similarly to starting it as a service and that I could then monitor/change its operation.
Have I missed something?
Thanks!!
Edited by kenbr - July 16 2008 at 20:17
jeffw_00 Super User
Posted: July 16 2008 at 22:32 | IP Logged
if you start powerhome as I suggested i don't think you can access it from your desktop. You're actually starting a 2nd instance but the first one has hold of the PLC. You could kill the first one and then restart it if you want access from your desktop. a freeware program like process.exe (which allows you to kill processes by name) could be used in a batch script called by an icon to kill and restart it in one step.
Or maybe dave can comment on how you can access a running powerhome from a different user
rboyleiii Newbie
Posted: July 31 2008 at 21:05 | IP Logged
I am running PH as a service on a headless computer.
I remote desktop to it with the /console option and I can launch the PH interface from the icon in the task tray.
Not sure if you can remote desktop to the same computer or not. (Never tried it, or had a reason to for that matter)
I am using a PLM, so I don't have SDM running and not sure what you would do about that.
HTH
Richard
dhewison Newbie
Online Status: Offline Posts: 25
Posted: August 01 2008 at 02:58 | IP Logged
I run PH as a service and use the following batch file to launch the console when I need to use it:
@echo off
net stop powerhome
"C:\Program Files\powerhome\pwrhome.exe"
net start powerhome
exit
This just stops the services, launches PH as an application, then when I exit the application it starts the PH service again.
David
kenbr Newbie
Posted: August 01 2008 at 08:08 | IP Logged
thanks richard and david. i'll give both of these a try. i did run PH as a service some time ago, and tried the /console switch with the remote desktop (i was running that system headless at that time too), but had some issues. i still access my PH system via rdc, and i think david's batch file solution may just be what i need.
thanks again,
kenb
