Subject Topic: DCC Issues Post ReplyPost New Topic
jpkelly100
Posted: January 25 2009 at 02:22 | IP Logged Quote jpkelly100
Will HomePower 2 communicate correctly with DCC 1.1 . I'm trying to get TTS from PH to the DCC, but when i Verify in the Formula builder on the PH machine,it keeps giving me a 401 Unauthorized. When i run the Formula i get no results at the DCC. The DCC is connected to PH and is listening for requests. I have turned firewall off on DCC machine. With the same 401 result.
Back to Top View jpkelly100's Profile Search for other posts by jpkelly100
jbbtex
Posted: January 25 2009 at 14:44 | IP Logged Quote jbbtex
Check your password in the dcc.ini. It must be the encryted version from the pwrhome.ini file under the [Socket Server] section.
Brady
jpkelly100
Posted: January 25 2009 at 21:35 | IP Logged Quote jpkelly100
I did a copy, paste to make sure i got the password correct. There was another post about that. I am at a total loss as to what is going on. The PH machine can see the DCC as it gives me that info above the 401 message. I'm an Admin on both machines, so i don't believe that is the issue either.
