Subject Topic: Adaptive Server Anywhere and Vista 64-bit Post ReplyPost New Topic
mcable1004
Posted: February 24 2009 at 15:54 | IP Logged Quote mcable1004
Hey All,
I'm trying to do a fresh install of PowerHome 2.1b on Vista 64-bit Home Premium edition. The problem I'm running into is that the Adaptive Server Anywhere driver is not being installed when I install PowerHome. When I did the install as a test on XP, it installed the drive automatically. Any ideas on how to resolve this? I did a quick google search to see if I could find the driver elsewhere, but couldn't find anything.
Any ideas?
Matt
Back to Top View mcable1004's Profile Search for other posts by mcable1004
Posted: February 24 2009 at 16:29 | IP Logged Quote BeachBum
My Vista Home & Business editions have to have PH run in Administrator mode and XP emulation. Not familiar with 64 bit Vista but some of the same issues probably apply.
Posted: February 24 2009 at 19:11 | IP Logged Quote TonyNo
I believe you need a special build for a 64-bit OS. Dave should know more.
Dean
Posted: February 25 2009 at 23:25 | IP Logged Quote Dean
BeachBum,
Are you able to run PH under a user account that is of type administrator and just set PH to run in administrator mode with XP emulation or do you also have to run it from "the" administrator account? I have problems under Windows Server 2008 (which people tell me is similar to Vista) unless I run PH using the default administrator account even though my own account is part of the administrator group. Hopefully my question is clear.
-Dean
Back to Top View Dean's Profile Search for other posts by Dean
Posted: February 26 2009 at 08:05 | IP Logged Quote BeachBum
Dean, I run it with an Administrator account authority in Administrator Mode in XP Compatibility Mode with All Users selected. I also have UAC turned off. The combinations of all 4 seem to work for me. If I recall, the All Users is what allowed the Adaptive Server to load.
mcable1004
Posted: February 26 2009 at 08:50 | IP Logged Quote mcable1004
Thanks for the suggestions, I'll run it in Administrator Mode in XP Compatibility Mode tonight. I'm not sure if the 64 bit difference will cause problems either.
My original problem was that I was trying to run the database upgrade utility. I thought since the driver wasn't listed in the ODBC drivers, that was causing the problem. Turns out, the problem was that I was giving it the wrong path to the db (Vista stuck an x86 in the Program Files directory name)
