Subject Topic: Looking for a VB script example Post ReplyPost New Topic
veropierre
Posted: May 27 2009 at 10:53 | IP Logged Quote veropierre
I wish to try my hand with VB scripting, I'm looking for a script example so I can play around a bit :)
Any lead?
Thank you.
Back to Top View veropierre's Profile Search for other posts by veropierre Visit veropierre's Homepage
Posted: May 27 2009 at 13:39 | IP Logged Quote grif091
This is about as simple an example as you can get. The Macro Formula invokes the VB script file which displays a Powerhome user message in the Event Log.
Macro formula statement
ph_runscript_0(0, "c:\temp\avbscript1.vbs", "sub1")
File c:\temp\avbscript1.vbs
@language="vbscript"
Sub sub1()
     ph.usermessage("user message from vb script")
End Sub
device
Posted: May 27 2009 at 17:57 | IP Logged Quote device
Well, I am a triple newbie (new to VBScript, SQL and powerhome over the past couple weeks). Here is the first VBScript I ever wrote (back in the days of yore - a couple weeks ago). It enumerates all the tables and all the columns of all the tables in powerhome into a text file (tables.txt) so I can use an editor to search for names when I am writing in another new language SQL and need table and/or column names.
Have fun,
D
Function enumtables()
     On Error Resume Next
    enumtables = "failed"
     Set fso = CreateObject("Scripting.FileSystemObject")
     Set tableinfo = fso.CreateTextFile("c:\Program Files\powerhome\tables.txt", True)
     Set fso = Nothing
     sysstatus = ph.sqlselect(1, "SELECT * FROM sys.syscatalog")
     If (sysstatus = 0) Then
           enumtables = "success"
           tablecount = ph.getsqlrows(1)
           For tableindex = 1 To tablecount
                tablename = ph.getdata_cn(1, CLng(tableindex), "tname")
                If tablename <> "SYSUSERPERM" Then
                      tablestatus = ph.sqlselect(2, "SELECT * FROM " & tablename)
                      tableinfo.WriteLine("Table : " & tablename)
                      If (tablestatus = 0 Or tablestatus = 2) Then
                           colcount = ph.getcolcount(2)
                           For colindex = 1 To colcount
                                 colname = ph.getcolname(2, CLng(colindex))
                                 coltype = ph.getcoltype(2, Clng(colindex))
                                 tableinfo.WriteLine("      " & CStr(colindex) & " : " & colname & " : " & coltype)
                           Next
                      Else
                           enumtables = "success with errors"
                           tableinfo.WriteLine(" &nb sp;    Error " & CStr(tablestatus) & " opening " & tablename)
                      End If
                      tableinfo.WriteBlankLines(3)     &n bsp;         &n bsp;
                      ph.sqldestroy(2)
                End If
           Next
           ph.sqldestroy(1)       &n bsp;
     End If
     tableinfo.Close
     Set tableinfo = Nothing
End Function
Back to Top View device's Profile Search for other posts by device
device
Posted: May 27 2009 at 18:02 | IP Logged Quote device
Some formatting got mangled so you will have to de-HTMLize the example to use it.
D
veropierre
Posted: May 28 2009 at 09:21 | IP Logged Quote veropierre
Nice, thank you!
Posted: May 28 2009 at 11:19 | IP Logged Quote dhoward
D,
Are you sure you're a newbie ?
device
Posted: May 28 2009 at 14:30 | IP Logged Quote device
Only claimed to be a newbie to VBScript, SQL, and Powerhome. I suppose I should have had full disclosure and confessed to having done a few other things in my life.
D
