PowerHome and Elk
 PowerHome Messageboard : PowerHome and Elk
Subject Topic: Serial connection to ELK M1-G Post ReplyPost New Topic
ivanpiro
Posted: June 17 2009 at 17:56 | IP Logged Quote ivanpiro
My PC is about 50 ft. away from my ELK M1-G. I built a serial cable using
cat 6 plenum cable. The ELM only requires 3 wires (2=2, 3=3, & 5=5) as
shown on page 7 of the ELK M1 manual.
Using the cable I described above, I'm able to run the thr ELP-RP program
and connect with the ELK without any problem. Should I be able to use
the same cable (after disconnecting from ELK-RP) using PowerHome to
connect to the ELK (from the same PC)?
My attempts to far have been unsuccessful.
Thank you,
Ivan
Edited by ivanpiro - June 18 2009 at 08:20
ivanP
Back to Top View ivanpiro's Profile Search for other posts by ivanpiro
ivanpiro
Posted: June 18 2009 at 11:22 | IP Logged Quote ivanpiro
Update.
The cable works! YES!!! Apparently I had the baud rate set too low.
Ivan
ivanP
