Subject Topic: PH as a service; restarting system Post ReplyPost New Topic
mike0999
Posted: September 20 2009 at 18:05 | IP Logged Quote mike0999
Hi All,
I am running powerhome as a service. When I select "restart" using the "start" menu, my computer does not respond. It appears that powerhome is causing the behavior because if I kill the powerhome service, the computer will restart fine.
Searching the forums, I found the following thread.
http://www.power-home.com/forum/forum_posts.asp?TID=1329&KW= service
In the thread, there is a post by wasdvd that says:
"Using R11 on my XP Pro, once the service is running using the instructions above, I am not able to shutdown or restart the PC unless I stop the service first.
Since I have stopped the service, I am able to restart the PC, but PH does not seem to restart automatically once the PC is restarted."
This appears to be the same behavior I am seeing, except I don't have any problems with startup.
Dave's response appeared to be to recommend use of a batch file to shutdown/restart the computer to address the issue. I could not tell if this meant that it is not possible to restart the system from the normal gui when running powerhome as a service. Is that the case? I suppose there is probably a way to have the batch file execute when I try to shutdown or restart and/or maybe there is another solution I haven't found yet. I'll keep searching to see if I can figure it out, but if anyone has any recommendations, appreciate the help.
Mike
Edited by mike0999 - September 20 2009 at 18:07
Back to Top View mike0999's Profile Search for other posts by mike0999
