jbbtex Senior Member
| Posted: November 05 2009 at 12:32 | IP Logged
I'm trying to create a timed event that uses a GV in the boolean field.
If I put {MYGLOBAL} in as the boolean of the ph_createtimedevent1 formula, {MYBLOBAL} gets evaluated and in the Timed Event listing the boolean field contains the value of {MYGLOBAL} rather than the string {MYGLOBAL}.
Any ideas on a work around?
__________________ Brady
| Posted: November 05 2009 at 13:21 | IP Logged
Try putting the Global variable name in quotes. The following example creates a Timed Event that fires 1 minute after being created. If GBOOLEAN1 is set to 1 the Macro is executed 1 minute later. If GBOOLEAN1 is set to 0 the Macro is not executed. If the quotes do not work post the actual ph_createtimedevent1 statement.
ph_createtimedevent1("NowPlus1",1,0,0,1,1,DATETIME(TODAY(),N OW()),0,"MMESSAGE1","{GBOOLEAN1}")
| Posted: November 05 2009 at 13:39 | IP Logged
I may not have understood your original question. If you are looking for a method to have the Global variable evaluated at the time the Timed Event fires rather than when the Timed Event is created use the following...
ph_createtimedevent1("NowPlus1",1,0,0,1,1,DATETIME(TODAY(),N OW()),0,"MMESSAGE1","ph_getglobal_s('GBOOLEAN1')")
Edited by grif091 - November 05 2009 at 13:44
| Posted: November 05 2009 at 17:30 | IP Logged
Heh, I think he's looking for something like this:
ph_createtimedevent1("NowPlus1",1,0,0,1,1,DATETIME(TODAY(),N OW()),0,"MMESSAGE1","{" + "GBOOLEAN1" + "}")
This should actually insert the global variable into the boolean field without evaluating it.
| Posted: November 05 2009 at 20:28 | IP Logged
That's it, exactly. Thanks.
