Subject Topic: Thermocouples? Post ReplyPost New Topic
rmackay
Posted: January 05 2004 at 16:41 | IP Logged Quote rmackay
Hi there,
I would love to be able to monitor indoor, outdoor, pool, and jacuzzi temperatures with my PH and WF800RF32. Does anyone know of any thermocouples (fancy term for temp sensor) that would relay the temp via wireless X10 signal?
Thank you,
Robert
Back to Top View rmackay's Profile Search for other posts by rmackay
Posted: January 05 2004 at 17:30 | IP Logged Quote TonyNo
There are wired devices available. These range from 1-wire temperature sensors (from Dallas Semiconductor) to actual thermocouple input devices with serial comms.
Wireless seems like a good idea, but, the device would have to transmit the temp reading every so often, and, collisions could be a problem.
From what I have seen, the 1-wire solution seems the best. When I get home, I'll post some links.
Tony
rmackay
Posted: January 05 2004 at 19:14 | IP Logged Quote rmackay
Yeah, but I don't want to have to run a wires from my Jacuzzi and Pool all the way back into my house. Wireless would be great if it did NOT send the data unless it was requested to by PowerHome somehow.
Posted: January 05 2004 at 20:00 | IP Logged Quote TonyNo
If you like to mess with electronics, this is the way to go...
Here is one link to info on the 1-wire sensor. He talks about interfacing, and, has some software.
http://www.sunpoint.net/~thermometer/
Dallas Semiconductor has a USB to 1-wire adaptor (DS9490R) for $13.75.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3834/ln/en
Here are the temperature sensors...
http://para.maxim-ic.com/compare.asp?Fam=Temp_Sens&Tree=1Wire&HP=1-Wire.cfm&ln=&SORD=448&FT_448=7872&FT_448=8087&ITEMLIST=119437,119438,119439,119440,119441,119442,119443,119444
I just found an X-10 device for this ($60 though)...
http://www.smarthome.com/1625.html
Plus, it looks like you may need a $30 gizmo (X-10 maxi controller) to make this work, too.
Posted: January 06 2004 at 13:51 | IP Logged Quote TonyNo
I never noticed your reply between my posts!
I don't think any of my finds can be submerged, though.
Tony
