Subject Topic: Syntax for ph-cgi/eval? Post ReplyPost New Topic
traviskleckner
Posted: December 07 2009 at 14:32 | IP Logged Quote traviskleckner
I'm trying to troubleshoot why the new iPhone won't work
for me. The logs seem to indicate that it's using /ph-
cgi/eval calls. I thought that something like (of course
insert server and port numbers that are for your setup):
http://server:8800/ph-cgi/eval?
formula=ph_getinsteonlevel("TESTSL")
should work, but I just get a page not found. Using
http://server:8800/ph-cgi/formula finds the formula page
just fine. Control center in general seems to be fine.
Am I doing something crazy?
Back to Top View traviskleckner's Profile Search for other posts by traviskleckner
Posted: December 07 2009 at 14:42 | IP Logged Quote grif091
Kevin has been posting examples with port number 8080 where your sample is using 8800. I don't use the stuff you are working with so this may not be important.
traviskleckner
Posted: December 07 2009 at 15:44 | IP Logged Quote traviskleckner
It shouldn't. I've got another app using 8080, so that's
why I'm on 8800.   But the app is logging results, so it's
getting to PH, it's just not doing anything.
Posted: December 07 2009 at 19:24 | IP Logged Quote TonyNo
That format works for me.
traviskleckner
Posted: December 08 2009 at 15:19 | IP Logged Quote traviskleckner
Interesting...so that format works for other people but
doesn't work on mine. Anyone have any thoughts on how I
went about breaking that, and more importantly, how can I
make it work again?
