RichardL Senior Member
Posted: January 18 2010 at 12:53 | IP Logged
In my VBS code, if I use iOn, iOff, etc in my commands I get a Syntax Error. If I change these to their corresponding "17", "19", etc. all is OK.
Is there an include statement, or something I am missing?
Thank you.
Posted: January 18 2010 at 13:19 | IP Logged
If you see the syntax error at execution time in the log then this is a known error. There is a problem with false systax errors associated with Insteon commands.
Posted: January 18 2010 at 14:22 | IP Logged
Where are you using ion and ioff? If the statement is being parsed by VBS it would not know of values that Powerhome would normally parse.
Posted: January 18 2010 at 14:25 | IP Logged
Thanks for the quick reply.
So I can use the iOn, iOff variables and ignore the Syntax Errors. The code will execute as it should?
Posted: January 18 2010 at 14:28 | IP Logged
Lee (just saw your reply) - Yes, I am using VBS. I am using it in PH.Insteon, PH.InsteonGroup, PH.InsteonGroupCU commands, and maybe a few others. Right now everything has 17, 19, etc, but better programming practice was to use the constants. I then saw the syntax errors and backed off.
Posted: January 18 2010 at 14:37 | IP Logged
I just did a simple test to manually run a trigger with a VBS attached to it.
The VBS had one PH.Insteon command in it.
If I use 17, the lights turn on.
If I use iOn, the lights do not turn on, and I get a syntax error.
Yes, this does either look like an issue with PH/VBS, or some form of "include" statement from PH is needed...
Posted: January 18 2010 at 15:33 | IP Logged
And CMD2 has the same value in both?
Posted: January 18 2010 at 16:18 | IP Logged
I scanned the powerhome directory/subdirectories and found nothing that defined ioff. Values like ion/ioff work in ph_xxxx calls as Powerhome is parsing and processing those statements. With various script syntax formats being supported by Windows Script Processor PH would have to have a unique file for each script format. Does not look like such an animal exists.
Posted: January 18 2010 at 16:25 | IP Logged
Pete - yes, the commands were identical:
rv = PH.Insteon("XBR-HH-Hall", 17, 250) vs.
rv = PH.Insteon("XBR-HH-Hall", iOn, 250)
Pete showed me way back about the script server checkbox that got me going there. I was hoping for something equivalent. I agree that the exernal WSH would need some form of a link.
Not a biggie, I'll define constants at the top of my code and run from there.
Posted: January 18 2010 at 16:29 | IP Logged
Sounds like a bug to me.
Posted: January 18 2010 at 23:54 | IP Logged
Yep, I tried to avoid that ugly word!
I will end up editing all my VBS to use constants anyway. If things change, I can do a quick replace of my constants to iOn,iOff,etc.
I appreciate the help!
Posted: January 21 2010 at 00:06 | IP Logged
I tried using constants in the VBS, and it only works a specific way:
The following 2 examples will NOT work:
iOn = 17
iOff = 19
rv=PH.Insteon("ID", iOn, 255)
iOn = 17
iOff = 19
iOn = int(iOn)
iOff = int(iOff)
The following example WILL work:
iOn = 17
iOff = 19
rv=PH.Insteon("ID", int(iOn), 255)
VBS has no variable types, so the conversion to integer has to happen in the command itself.
I simply reverted back to using no constants, and the raw (17, 19, etc) values, easier...
Posted: January 21 2010 at 00:18 | IP Logged
So I did not go down the wrong path before, you are seeing a VBS syntax error from this and not a powerhome event log error.
Posted: January 21 2010 at 02:43 | IP Logged
Did you try defining them as Constants
Const iOn = 17
Const iOff = 19
EDIT: The following works here ....
Const iOn = 17
ph.usermessage("test message from function")
ph.usermessage("second message from function")
rv=ph.insteon("ICON SWITCH TEST", iOn, 254)
Edited by grif091 - January 21 2010 at 09:39
Posted: January 21 2010 at 14:14 | IP Logged
Pete. the reason this is not a bug is the example below also works and as you can see Powerhome knows nothing about ion10 and ion7. The ion variable is evaluated by the Microsoft Windows Script Host processing before Powerhome ever sees the statement. Without ion being defined to WSH it is null and is the equivalent to issuing ph.insteon("ID", , 254) which of course is invalid. From the example below you can see that WSH evaluated ion10+ion7, substituted the result, 17, which is now a valid value for Powerhome. Just as ion10 and ion7 are not passed to Powerhome, ion is not passed to PH. One could argue that PH should provide a file for every possible script format that WSH accepts so that values such as ion could be used. However, with all the other things that Dave needs to spend time on, I2 support, Extended command support, CC additions, etc, things that we cannot do without functional additions to PH, I think this is low on the requirements list.
const ion = 17
const ion10 = 10
const ion7 = 7
rv=ph.insteon("ICON SWITCH TEST", ion10 + ion7, 254)
Just the ramblings of a very dusty old man after vacuuming leafs for two days.
Posted: January 21 2010 at 16:58 | IP Logged
Lee, I see your point but if ph.insteon doesn’t work as described in the Help file then maybe the Help file needs to be fixed to address the work around.
I just have to pickup palm fronds. …
Posted: January 21 2010 at 23:06 | IP Logged
Well I'm sure glad that the dust and leaves did not mar your tech side!
So here I am a coder for a few decades and didn't think of the darn "const" - as they say "bust my buttons" that works! It's always good to share issues and ideas.
I'm real glad since I hate hardcoding things. Time to retrofit all that code (again)!
No palm fronds here, just some skiing on Saturday!
