Subject Topic: Triggers with Dim/Bright Post ReplyPost New Topic
RichardL
Posted: March 03 2010 at 16:06 | IP Logged Quote RichardL
I am using triggers with the "Insteon Group In" (thanks Lee) to sense SwitchLincs and KPLs being turned On or Off with no problem. I have tried the same config but using the Bright and Dim setting, and it does not seem to work. I simply want to have different (dim/bright) triggers get launched if someone presses and holds a SwitchLinc to make it dim or bright. Any ideas?
Back to Top View RichardL's Profile Search for other posts by RichardL
Posted: March 03 2010 at 17:34 | IP Logged Quote grif091
Try the Trigger Value of Start Man Chg (0x17). This is the command issued when a paddle/button is pressed and held. The Stop Man Chg command (0x18) is issued when the paddle/button is released. If someone happens to double tap the paddle/button you get a command Fast On (0x12).
RichardL
Posted: March 03 2010 at 17:57 | IP Logged Quote RichardL
I saw that (there are also alot of other real cool items there...one day), but can that tell me if the paddle was dimmed versus brightened?
I want to have triggers if the SwitchLinc gets brightened, and different triggers if it gets dimmed...
Posted: March 03 2010 at 18:13 | IP Logged Quote grif091
The cmd2 field indicates direction of change. 0x00 = down,   0x01 = up.   Display the temp variables in the macro that is invoked by the trigger. Not sure if PH passes the cmd2 value on to the macro.
Posted: March 03 2010 at 19:04 | IP Logged Quote grif091
Looks like temp3 is tracking with the cmd2 value. You can check temp3 for Up (1) or Down (0).
RichardL
Posted: March 14 2010 at 17:22 | IP Logged Quote RichardL
Got it, works fine!
I set the trigger for Start Man Chg (0x17), the trigger does a PH_RunScript_1, where I included [TEMP3] as a parameter. In the code I handled the 0 for dim, a 1 for bright.
More good stuff.
Thank you again!
Richard
