Subject Topic: Does Script Server work w/Windows 7 x64 Post ReplyPost New Topic
strav
Posted: June 07 2011 at 03:05 | IP Logged Quote strav
When I start Powerhome with the option to Load Script Server enabled, I receive the following error message:
"An error occurred while creating the script server: -2"
I'm running Windows 7 x64 with UAC off.
Powerhome Version 2.1.4, DB Version 2.1.2
Is there something I can do to make the script server work properly?
Steve
Edited by strav - June 07 2011 at 03:08
Back to Top View strav's Profile Search for other posts by strav
Posted: June 07 2011 at 07:21 | IP Logged Quote BeachBum
Check all the paths in PH INI and make sure they are set to the same as the default. I’ve had it on a couple installers and was able to fix it that way. One was a registry fix I found searching. I had another that Dave fixed by registering one of the files. Right now I can’t remember which had to be registered.
strav
Posted: June 07 2011 at 14:02 | IP Logged Quote strav
Hey Pete,
Thanks for the quick response. I double checked the paths in the PH INI file and they are set to the default ("c:\powerhome\*").
I found some potentially related information in this thread: http://www.myx10.com/forum/forum_posts.asp?TID=970&KW=script +server
I validated the information in phscr.reg was correct and re-imported the values just to be safe.
There was also a post in that thread (page 3) from bhlonewolf with another group of registry entries for HKLM instead of the default HKCU. I downloaded that file, edited the values (newer version of pbvm / paths) and imported that. Still no go.
Is there anything else I can try?
-Steve
Posted: June 07 2011 at 21:50 | IP Logged Quote BeachBum
I’m on the road so sorry for the delay. Do you have 213 and 214 also on? As I said earlier Dave fixed one for me I couldn’t fix and he told me what he did and as usual it went right over my head. Although it is related to the latest versions as I have had the problem with Vista and Win7 x64. And I do believe it has something to do with registering. I’ll keep researching it and see if I can find an answer for you.
strav
Posted: June 07 2011 at 22:17 | IP Logged Quote strav
Hey Pete,
No worries. I haven't had any need to use the script server up until now and it's by no means urgent. I appreciate the help regardless of the turnaround time. :)
Yes, I have 2.1.3 and 2.1.4 applied as well.
As far as registering, I made several attempts to register phscr.pbd activeX control as it seems that the "-2" error is related to powerhome not being able to find this control. I tried both the regsvr32 under \windows\system32 and the one under \windows\syswow64 and both displayed an error:
      The module "phscr.pbd" may not compatible with the version of Windows you are running. Check if the module is compatible with an x86 (32-bit) or x64 (64-bit) version of regsvr32
Please let me know if you figure out what you ended up doing to get it functioning properly on your system.
-Steve
Posted: June 07 2011 at 22:51 | IP Logged Quote BeachBum
Did you try this one:
regsvr32 "c:\powerhome\ph_scriptserver.ocx"
strav
Posted: June 07 2011 at 23:39 | IP Logged Quote strav
Pete,
You, sir, are a genius! That took care of it. Script server is currently running like a champ.
Many Thanks!!!
-Steve
