AllanMar Groupie
Posted: August 22 2011 at 19:14 | IP Logged
I've neglected my home automation for a bit, but I have a new house now so I'm back at it... So I know this has come up a few times before although I can't seem to find a post that solves the problem.
I have two lights I want to link to a single keypad button. Cross linked and they work fine. My issue is, when i turn only 1 light of the 2 off, the keypad button also turns off. My plan was to create a PowerHome trigger to turn the keypad led back on if one light of the two remains on. (I want to keep the linked behavior also).
I have two Insteon Dev Chg Triggers, one for each light.
Trigger ID: 1 Trigger Value: (ANY) Boolean:([LOCAL9] <> [LOCAL10]) AND ([LOCAL10] = 0 or [LOCAL9] = 0)
I was under the impression the [LOCAL9] <> [LOCAL10] should stop it from firing on ACK's/Cleanups. I have update on ACK enabled. Basically, my trigger is firing twice. Once when I send a command to turn off the light and again when the ACK is recv'd....
Insteon Out Insteon DM Controller PLM transmission of Address:[04.60.06] Flags:[15] Cmd1:[19] Cmd2:[0]. Decode: Direct. ID: GRGPOTSWITCH, Off
Trigger Check Trigger check of OUTSTATUPD GRG POT performed.
Macro Macro OUTSIDELIGHTSTAT executed.
Incoming Insteon received on Insteon DM controller PLM. From Address:[04.60.06] To Address:[19.6F.6F] Flags:[43] Cmd1:[19] Cmd2:[0]. Decode: Direct ACK. From: GRGPOTSWITCH To: PLM, Off
User Message LOCAL7:GRGPOTSWITCH LOCAL8:04.60.06 LOCAL9:0 LOCAL10:255
User Message LOCAL7:GRGPOTSWITCH LOCAL8:04.60.06 LOCAL9:255 LOCAL10:0
Any Thoughts? I wanted to use Dev Chg vs Group IN or similar so it would also handle the case of dev chg's from powerhome.
Posted: August 23 2011 at 10:30 | IP Logged
I have not been able to recreate the results you are seeing. What PH2 release are you running and what is the device type for 04.60.06?
From the trace data LOCAL10:255 does not track with the outbound command issued.
Posted: August 23 2011 at 11:10 | IP Logged
Try implementing trigdisable and see if that stops the double firing.
AllanMar Groupie
Posted: August 23 2011 at 11:35 | IP Logged
@grif091: V2.1b I believe, 04.60.06 is an old Icon Relay.
@BeachBum: I'll give it a shot this evening, Although I'd like to know why its behaving this way.
I don't get why Im getting the LOCAL9:0 and LOCAL10:255 and then another LOCAL9:255 and LOCAL10:0 for the same command.
Posted: August 23 2011 at 11:43 | IP Logged
I personally have never gotten the [LOCAL9] <> [LOCAL10] to work for me.
Posted: August 23 2011 at 12:47 | IP Logged
I am running 2.14 so not an apples to apples comparison. Used a KeypadLinc primary button and an ICON Relay, both with the same results. Local9=0, Local10=255 for the initial On paddle Group Broadcast. Local9=255 Local10=255 for the Group Cleanup.
The Off command was the expected opposite. I did not try to gate the Trigger, called a Macro for all Dev Chg events and displayed all the Local values as the first line of the Macro.
Posted: August 24 2011 at 12:32 | IP Logged
This is the Event Log from an Off issued from Device Status to create an Outbound event. Local9=255, Local10=0, the result of the Off. The Inbound ACK triggers again with Local9=0, Local10=0. There may be some issue with 2.1b that is resolved with 2.1.4.
The results previously posted from 2.1b may explain why Pete was not successful using Local9 <> Local10.
INSTEON PLM Controller HL2 PLM transmission of Address:[04.56.50] Flags:[15] Cmd1:[19] Cmd2:[0]. Decode: Direct. ID: ICON SWITCH TEST, Off
Trigger check of TDEVCHG performed.
Macro MATEST executed.
local1= local2= local3= local4= local5= local6= local7= ICON SWITCH TEST local8= 04.56.50 local9= 255 local10= 0
Incoming Insteon received on INSTEON PLM controller HL2 PLM. From Address:[04.56.50] To Address:[0F.44.DC] Flags:[43] Cmd1:[19] Cmd2:[0]. Decode: Direct ACK. From: ICON SWITCH TEST To: HL2 PLM, Off
local1= local2= local3= local4= local5= local6= local7= ICON SWITCH TEST local8= 04.56.50 local9= 0 local10= 0
Posted: August 25 2011 at 19:12 | IP Logged
Allan,
Not sure why your trigger would fire twice. The [LOCAL9]
<> [LOCAL10] technique should work just fine in version
2.1b.
Based upon your log info posted above, it appears that
your trigger is indeed firing twice on both the Direct
and ACK command but the User messages don't make sense.
The first one shows LOCAL9 = 0 and LOCAL10 = 255 and the
second one shows the reverse. What should happen since
its an OFF is that by the time the ACK is received, the
variables should be LOCAL9 = 0 and LOCAL0 = 0. Something
else must be going on.
Would it be possible to post either screenshots of your
triggers and the macro that is called or exports of the
above?
AllanMar Groupie
Posted: August 26 2011 at 17:46 | IP Logged
Attached are the two SQL outputs. The macro isn't really finished as I ran in to this issue...
2011-08-26_174533_macro.sql.txt
2011-08-26_174548_trigger.sql.txt
I've been planning to try 2.1.4, after seeing your post in that topic recommending it, I'll do it shortly. I will let you know if it makes any difference.
Edited by AllanMar - August 26 2011 at 17:47
AllanMar Groupie
Posted: August 26 2011 at 18:23 | IP Logged
Confirmed not an issue in 2.1.2. Exact same macro/trigger/links.
Posted: August 26 2011 at 19:43 | IP Logged
Install 2.1.4 on top of 2.1.2. It has some fixes for 2.1.2 and Local9/Local10 works as expected.
Posted: August 28 2011 at 23:30 | IP Logged
Did you try the trigdisable?
AllanMar Groupie
Posted: August 31 2011 at 14:47 | IP Logged
@BeachBum: No. As it is no longer an issue in 2.1.2 & 2.1.4 I have not bothered.
