Subject Topic: FLAGGED CREATE but not doing anything Post ReplyPost New Topic
MrGibbage
Posted: December 01 2012 at 10:54 | IP Logged Quote MrGibbage
I got a new appliance linc relay plug-in module (2456S3, ver 4.9) today and went to
build the links in it. Got all of the controllers in place, went to save it, saw the
controller links getting created but then it never built the responder links. Saving,
rebuilding, refreshing, still nothing. It doesn't even try to build them. They are just
sitting there, waiting to be built. I don't know if this is related to new Insteon
version, but I have other new devices and I don't remember seeing symptoms like this
before.
By the way, I searched the forums for "FLAGGED CREATE" and came up with 0 hits. Is the
search not working here? I am sure there must be other posts here that have the term
"FLAGGED CREATE".
I do have one more question related to the module, but not PowerHome. I am using this
module for Christmas tree lights, but I am seeing that even when the module is switched
off, the lights on the tree are still glowing dimly. I guess there is some bleed
through voltage??? This is strange to me because this is the relay version of the
module. My other tree doesn't have this problem, so I wonder if this is something
related to the new Insteon version as well?? Or maybe it's because this tree has LED
bulbs instead of regular bulbs. In any case, it is annoying. Anyone know a workaround
to make it really be off when it is off?
Skip
Posted: December 01 2012 at 11:15 | IP Logged Quote grif091
The 2.1.4 I2CS patch is required. In addition the Enable Pending and Status Scan options must be checked. The recognition of I2CS requires these two options be active.
Also make sure the Clear Failed column is not marked with a Red mark.
MrGibbage
Posted: December 01 2012 at 11:27 | IP Logged Quote MrGibbage
Lee, it was somehow marked as disabled in the devices tab. Strange, since I just
installed it. Not sure how it got marked as disabled. I have had the 2.1.4 I2CS patch
installed for several months.
I've still got that voltage bleedthrough issue though. Not a PH problem, I know. But
still annoying.
Skip
traviskleckner
Posted: December 04 2012 at 15:23 | IP Logged Quote traviskleckner
For what it's worth I brought up the same issue with a
dimmer Lamplinc last year on the Smarthome forums. The
answer I got then was that it's related to the sensing
circuit (so if a lamp is turned off and then back on it
triggers the Insteon Module). My Christamas tree does the
same thing as yours... apparently the tiny amount of
current there for the sensing is enough to make it light up
slightly.
Back to Top View traviskleckner's Profile Search for other posts by traviskleckner
MrGibbage
Posted: December 04 2012 at 16:07 | IP Logged Quote MrGibbage
I actually solved that problem by putting a wall wart
transformer downstream on the same circuit with the
Christmas lights. The transformer draws enough current to
keep the lights from coming on.
Skip
Posted: December 07 2012 at 07:35 | IP Logged Quote GadgetGuy
I've had the same problem with all my ceiling lights I
replaced with LEDs. The solution that works well, plus a
bonus of giving much better dimming control was to (only
easily works on multi-bulb fixtures) install a 8 watt
regular filament nite light bulb in the fixture with the
LEDs.
The small non-LED bulb uses up the small bleed current
and keeps the LEDs from lighting. Since the standard
bulb is so small in wattage, it contributes little to the
light output as the dimming intensity is raised (on a
dimmer circuit) and the LEDs prevail.
Really works well over the full intensity range.
With the tree lights, just put a multi-tap on the output
of the Insteon controller with the LED string and a small
light plugged in. I use small plug to socket converter
available at any hardware store.
I would have put a picture here but cannot upload the
image as I get an error every time.
FYI Dave it reads -
Server object error 'ASP 0177 : 800401f3'
Server.CreateObject Failed
/forum/functions/functions_upload.asp, line 234
800401f3
Posted: December 07 2012 at 08:43 | IP Logged Quote BeachBum
Believe it or not I actually tailed an extension cord from it and that solve the problem.
Posted: December 19 2012 at 08:27 | IP Logged Quote GadgetGuy
"FLAGGED CREATE".
Skip - I was tearing my hair out (what little I have left
as you can see from my Avitar) last week with a similar
issue after I added a KPL keypad with the new I2CS
protocol. All of the Controller and Responder links
would not change from FLAGGED CREATE no matter what I
tried.
I discovered that the "Disabled" flag for the Device
would not stay unchecked. If I cleared it and did a
Save/Refresh, the checkmark would come right back. After
days of frustration and with assistance on the side from
Dave we finally got it going by totally deleting the
Device entry and then re-establishing it using the
*AutoDetect Type* function in the Device Type column of
the Devices tab.
To assist others, Dave helped me write up a full
description of the process, which I have posted in this
thread . . . home.com/forum/forum_posts.asp?TID=3173&PN=1&TPN=1">
http://power-home.com/forum/forum_posts.asp?
TID=3173&PN=1&TP N=1
Edited by GadgetGuy - January 04 2013 at 07:44
Posted: January 03 2013 at 07:04 | IP Logged Quote TonyNo
Seeing similar things here. Status Scan needs to be checked all of the time?
Posted: January 03 2013 at 07:17 | IP Logged Quote GadgetGuy
Unless someone advises otherwise, I don't think that
"Status Scan" needs to be checked. At least when I am
working on Link rebuilding I usually uncheck "Status
Scan" and wait for the Pending window to clear so I can
better see what is going on.
To speed up the link rebuilds, I also make the "Poll
Interval" a "1" instead of the normal "10" I usually have
it set at. That way the Pending Ops shoot out at a rapid
rate instead of pausing 10 seconds between each
operation.
Have you looked at the process description link I posted
just above? Dave assisted greatly in helping me write
that up, and at least for my issues it worked well.
Posted: January 03 2013 at 19:15 | IP Logged Quote TonyNo
Ooh. Missed that. Thanks!
Posted: January 09 2013 at 07:33 | IP Logged Quote GadgetGuy
Well crap! It's happened to me now!
I have an IR-Link that controls all my Home Theater lighting, and is thus the most critical device I have!
It has been acting up so attempted a Rebuild Links on it. That posted all of the rebuild commands in the Pending Queue, but as soon as the first Controller Link 1 operation moved from Pending to Completed, the Pending Queue was cleared and the Disabled Flag was set on the IRLINK Device.
I have tried everything to make it work, but without success. In short I have . . .
  • Made sure Enable Pending and Status Scan were checked
  • Cleared Disabled Flag after every try to Rebuild
  • Reinitialized multiple times
  • Cleared PLM and Added Min
  • Cleared PLM and Added Max
  • Restarted PH
  • Did auto discovery on IRLINK device to make sure it was correct (it was)
This happened to me several weeks ago on a different device and Dave got it going, but he had to delete the Device and start again from scratch. Unless anyone has any better ideas, it looks like I'm going to have to do the same thing.
Of course, this is one of the most complex link configurations in my entire system, so I'm looking at a major effort here.
As a last resort I'm about to do a db compression to see it that catches any issues. I'll report back what happens.
Posted: January 09 2013 at 08:38 | IP Logged Quote GadgetGuy
db compression made no difference, so I bit the bullet and did what Dave had to do when he fixed this issue the last time for me.
Since this approach fixed the problem, here are the steps I took . . .
1. Add a new Insteon Device (Devices Tab) with same name but modified temporarily. Give it same Insteon address but change first character to “V” to make it ‘virtual.” (This is necessary because you cannot have two devices with the same address, so we must tempporarily fake this one.)
2. Re-initialize to add new device to database.
3. In Links Tab select old device and COPY links (do NOT include self as Responder). PASTE into the replacement device and Save changes.
4. Delete old device from Devices Tab, then re-Initialize PH.
5. Change new device Addr from ‘Virtual’ to correct addr, and re-Initialize.
6. Finally select new device and Save changes to force link rebuild and then in Setup Tab Clear PLC Database and Add Insteon ID info back.
Whew! A bit of work, but it seems to do the job.
