Subject Topic: Control KPL leds? Post ReplyPost New Topic
mmoore99
Posted: February 04 2013 at 01:41 | IP Logged Quote mmoore99
Is it possible to setup a KPL in such a way that when
button 3 is turned on, buttons 4, 5 & 6 can be forced to
turn off?
Back to Top View mmoore99's Profile Search for other posts by mmoore99
Posted: February 04 2013 at 06:33 | IP Logged Quote grif091
Sure. If it is an I2CS KeypadLinc, not under current Powerhome.   Release 2.1.5 should have that support, there is no estimate when that will be available.   If it is an older KPL try the Insteon Explorer | KPL Config tab.    That should work if not an I2CS device.
They are sometimes referred to as operating as Radio Buttons or Mutually Exclusive buttons. Note that the function is only controlling the button LEDs. The devices controlled by buttons 4,5,6 are not directly affected by the KPL LED button behavior.
Edited by grif091 - February 04 2013 at 06:34
mmoore99
Posted: February 04 2013 at 11:24 | IP Logged Quote mmoore99
Thanks...that did the trick!
