| Posted: September 19 2004 at 22:07 | IP Logged
Beta version 1.03.4.1 of PowerHome is now available for download.
Lots of new features including the highly anticipated USB-UIRT support. Changes to the Control Center has forced the changing of some formula functions so be sure and read the Special Notice section of the User's Manual.
Speaking of the User's Manual...it has not been updated with the latest changes for this release (one of the reason it's a beta ) but most of the changes should be self explanatory.
If you are upgrading...be sure and follow the upgrade procedure in the README.RTF. Basically you'll rename your existing PowerHome directory, install the new version to a different directory (the default since you renamed your old), copy over your old pwrhome.db and pwrhome.ini files (as well as any others you've created such as web pages, etc), run the PHUPG.EXE program to upgrade both your database and INI file, and run PowerHome. You can use the new "Database Where Used" report to help you find occurrences of the functions you'll need to change.
