Handman Senior Member
| Posted: July 22 2014 at 14:43 | IP Logged
I am using the new 2.1.5 PH. I am trying to replace a 6-key Smarthome 2486D KeypadLinc with a newer 2486DWH8 8-key KeypadLinc Dimmer device. I swapped devices (physically) and then used the discover function to get the info on the NEW DEVICE1. So far so good. I tried to add the old device ID in the NEW DEVICE1 Replace Address column in Insteon Explorer under the Device tab, but I get an error message saying, "DATA WINDOW ERROR: Proper address format is XX.XX.XX where XX is a hexidecimal number from 00 to FF." When I try to use either the ReplaceID or SwapIP drop down list to select the replaced device, I get another Data Window Error message which says, "Item 07.98.76 does not pass the validation test."
Am I doing something wrong? Can I not transfer the links from a 6-key device to a newer8-key device?
| Posted: July 22 2014 at 15:18 | IP Logged
Handman,
The datawindow error is in version 2.1.5. Version 2.1.5a was released to fix this specific error and a few others. You would need to check that thread for download and install instructions.
However, once you do get 2.1.5a up and running...if you're simply trying to replace a device with another new device, you don't want to auto discover it or add it to PowerHome in any way. Just put the new device address in the Replace Address column and hit save. It will use the existing record and recreate all the existing links. Since you've already added this device, you'll want to delete the NEW DEVICE1 line (and save) then put its address in the Replace Address column.
| Posted: July 22 2014 at 20:06 | IP Logged
Thanks Dave. I did it the right way in 2.15 with the Replace column, but when I got the error I thought it something I did wrong. The upgrade and replace went swimmingly!
| Posted: July 22 2014 at 20:28 | IP Logged
Handman,
Awesome! Thanks for reporting back .
