PowerHome Macros, Scripts, and Formulas Repository
 PowerHome Messageboard : PowerHome Macros, Scripts, and Formulas Repository
Subject Topic: Importing Cumulus weatherdata in PH Post ReplyPost New Topic
krommetje
Posted: October 18 2014 at 01:39 | IP Logged Quote krommetje
If you use Cumulus for your weatherstation and you upload it to your own site, you can import your own data into ph by using realtime.txt which Cumulus uploads also:
this code will return the 10th data item for you:
ph_parseline(ph_parseline(ph_geturl("http://www.website.com/ realtime.txt"),"~r~n~r~n",2)," ",10)
By changing de number 10 in the example you can import all weatherdata you need.
the file realtime.txt is explained here: http://wiki.sandaysoft.com/a/Realtime.txt
p.s. watch the boardbug... it striked again...
Edited by krommetje - October 18 2014 at 01:41
