Viper Groupie
Posted: January 31 2015 at 07:29 | IP Logged
I wasn't quite sure how to search for this before I posted, so please forgive me if it is a known problem.
In Triggers, if one field, say the Action field, causes the row to expand vertically, it appears that the Trigger ID field is going past the end of the Trigger ID variable and grabbing extra data. Not a problem unless it hits the end of a segment which might cause an exception.
Tom
gg102 Senior Member
Posted: January 31 2015 at 11:08 | IP Logged
Be advised, this also happens in Macro Detail:
Posted: January 31 2015 at 11:27 | IP Logged
Tom,
Nothing to worry about . That data is always there
and is just normally hidden by the size of the row.
Its just internal values used within PowerHome
relevant to proper operation.
I'd like to figure out a way to "hide" them as they do
kind of detract when the row autoexpands (it wasnt a
problem in earlier versions when autoexpansion wasnt
there).
I'll take a peek and see what I can do about hiding it
but in the meantime, its normal and won't affect
operation.
