flyred Newbie
| Posted: September 11 2006 at 12:10 | IP Logged
Hi folks,
My old computer that PH runs on is about to give up the ride. I am going to move it to another computer. Anything special considerations for this task?
| Posted: September 11 2006 at 13:31 | IP Logged
The easiest thing to do is a clean install, then copy over your databse and ini file. Don't forget any other files you may have put in the ph folder or below!
flyred Newbie
| Posted: September 11 2006 at 15:03 | IP Logged
Thanks, Just wanted to make sure that I wouldn't miss something!. I think I can handle this!
krommetje Super User
| Posted: September 13 2006 at 13:56 | IP Logged
If you have to put in the work anyway, I recommend a clean install of Windows Too... the less overhead the Processor has to deal with the more resources can be given to PH...
New PC's nowadays are not equiped with serial ports and other hardware like it, otherwise I would buy a new system, with a clean install of windows... preferably XP or 2003 server...
