PowerHome Feature Requests
Subject Topic: Insteon Explorer Post ReplyPost New Topic
UpstateMike
Posted: October 02 2006 at 21:13 | IP Logged Quote UpstateMike
Is it possible to freeze the ID field under the Devices tab of Insteon Explorer so that you can still see it when you scroll to fields on the far right?
Back to Top View UpstateMike's Profile Search for other posts by UpstateMike
Posted: October 02 2006 at 22:06 | IP Logged Quote dhoward
Mike,
Absolutely. At the bottom of the window, just to the left of the left arrow for the horizontal scrollbar is an area that when you mouseover will change to a resize pointer. Click and drag to the right to split the window into two separate sections. You can then set the left hand section to show only the ID and then scroll the right-hand window to show all the fiels.
UpstateMike
Posted: October 02 2006 at 23:31 | IP Logged Quote UpstateMike
Much better, Thanks!
