        | npavkov Groupie
          I have successfully upgraded to new beta version 1.03.4.8, and converted the db fine also. However I have a problem because I have a startup macro which minimizes PH to the system tray (and locks out the click to bring it up from the tray....for security reasons.) However, I forgot to rename the startup macro before upgrading and now I can not get PH to allow me to access it (since the controllers are gone from upgrading, and I utilized a remote x10 switch to bring it up from system tray to access it)
           | Posted: October 03 2006 at 23:05 | IP Logged |   |
 IS there anywhere to keep the startup macro from running on startup, when I can not access PH to rename it or anything in the db..... Help please!!!!
        | Back to Top |     |
        | TonyNo Moderator Group
          You should be able to modify the pwrhome.ini file...
           | Posted: October 03 2006 at 23:27 | IP Logged |   |
 [Script]
 STARTUPMACRO=
 Edited by TonyNo - October 04 2006 at 00:01
        | npavkov Groupie
          Thanks Tony, I will try that later today......
           | Posted: October 04 2006 at 07:49 | IP Logged |   |
        | Back to Top |     |
        | krommetje Super User
          When can it be downloaded?
           | Posted: October 04 2006 at 09:53 | IP Logged |   |
          It's available now. See Dave's recent post.
           | Posted: October 04 2006 at 13:33 | IP Logged |   |
