         mcable1004 Newbie
           | Posted: March 22 2007 at 09:13 | IP Logged
Hi Everyone,
 I've been reading the forums for a while, and decided it was finally time to post a question
 Is there a way to set the X10 address for an Insteon SwitchLinc with PowerHome?  I've been trying to set it using an X10 Mini Timer and following the instructions that came with the SwtichLinc, but haven't had any luck.
 Matt
         cmhardwick Senior Member
           | Posted: March 22 2007 at 10:42 | IP Logged
Yes you can. If you look on the Devices screen, and scroll over, there is a column for X10 address. I'm NOT sure, but I think after you put it in and save it, and make sure it gets to the switchlinc, you need to pull the airgap on the switchlinc for a few seconds to kill power to it then pop it back in (don't hold it in, or you'll do a factory reset). I don't use X10 addresses, so I'm not sure of the exact steps.
         mcable1004 Newbie
           | Posted: March 26 2007 at 10:54 | IP Logged
I checked out the Devices screen.  I see that you can set the "Desired X10 Address", but that doesn't really seem to do anything.  The light still doesn't respond to the x10 commands, and the "X10 Address" column is never set.
           | Posted: March 26 2007 at 11:07 | IP Logged
after you did the Desired X10 address, you saved the changes.
 on the top of the insteon explorer window, make sure you put a checkmark in WRITE X10 address (it's off by default) I would also, so you can verify, make sure READ X10 Address is also checked.
 Hope this helps!
