| Posted: November 14 2002 at 16:29 | IP Logged
Bob,
You can download the PowerHome command line utility from the other downloads page.  This utility uses the web server interface and doesn't require IE.  It can be executed from the command line and allows you to pass in a Send Keys formula.  When done, it automatically closes itself.  Using your above example the command line would look like: phcommand.exe ph_rtne(ph_macro("TEST"))
Using this utility you won't be limited to just macros and will be able to evaluate any send keys formula.
