         MrGibbage Super User
           | Posted: June 23 2007 at 16:02 | IP Logged
I have a big PLC group (about 20 devices... big to me anyway) that when I have PH turn on or off, PH kinda hangs for about 10 minutes.  PH is still running, but things get REEEEEAAAAAAALLLLLLLL Slow.  Eventually, it gets back to normal.  The SDM log shows this, over and over, while PH is in this hanging mode:
 PLC:eventraw=03
 PLC:SRIR=send failed
  ui:srir=00 00 00 09 9C 72 45 12 05
  uifinished:srir=00 00 00 09 9C 72 45 12 05
  si:08 A7 75 09 9C 72 45 12 05
  ui:srir=00 00 00 09 56 50 45 12 05
  uifinished:srir=00 00 00 09 56 50 45 12 05
 PLC:eventraw=03
 PLC:eventraw=04
 PLC:receiveinsteonraw=04 09 9C 72 08 A7 75 65 12 05
 6/23/2007 3:58:43 PM:ackmsg=09 9C 72 08 A7 75 65 12 05
 PLC:eventraw=03
  si:08 A7 75 09 56 50 45 12 05
 PLC:eventraw=03
 PLC:eventraw=04
 PLC:receiveinsteonraw=04 09 56 50 08 A7 75 61 12 05
 6/23/2007 3:58:48 PM:ackmsg=09 56 50 08 A7 75 61 12 05
 What SRIR?  What do I do to fix it?  Reset PLC?  Is that what is causing PH to hang?
 Skip
           | Posted: June 23 2007 at 16:13 | IP Logged
By the way, all of the lights in the group turn on and off as expected, but this 10 minute pregnant pause is disturbing.
 Skip
           | Posted: June 23 2007 at 16:16 | IP Logged
Skip,
 Check out this post  http://www.power-home.com/forum/forum_posts.asp?TID=1318&PN= 1 and my response.  It's the same problem  .
           | Posted: June 23 2007 at 17:07 | IP Logged
Awesome, Dave.  Thanks.
 Skip
