Subject Topic: Feature Request: Trigger/Timed Event org. Post ReplyPost New Topic
bhlonewolf
Posted: November 29 2007 at 21:40 | IP Logged Quote bhlonewolf
AFAIK I may be the only one who wants this, but ...
Would it be feasible to allow foldering or other grouping of timed events and triggers? After about 15 or either, it starts to get hard to sort through. Case in point: I have a ton of timed events that only occur when I'm "away" -- it would be great to file 'em all in a folder or such.
Thx!
Brian
Posted: November 29 2007 at 22:28 | IP Logged Quote TonyNo
Hmm. Maybe sort on Boolean field?
Posted: November 29 2007 at 22:30 | IP Logged Quote dhoward
Brian,
Heh, you're not the first. This has actually become a fairly popular request as of late. Not just for Timed Events and Triggers, but for Macros and other screens as well.
Since it has become popular, Ive been trying to think of a good way to implement this without having to make massive database changes.
Now the first way most people may think of doing this (especially in terms of a SQL database) would be to add an extra column to all tables to hold a new value representing what group the data belongs to. These are the massive database changes that Im tyring to avoid. It also means that each trigger, timed event, etc. can ONLY belong to 1 group.
Ive been toying with another idea. Creating a separate table that holds group information. Basically it would be a many to one type of relationship that allows you to put the same Trigger ID, timed event, macro into multiple group ID's. Then, when you open the PowerHome Explorer, a new little selection window would allow the user to select the current group to view, including ALL Groups, and unassigned groups. I think I can accomplish this fairly easily using database filtering rules. With this approach, you would have a separate "Group" creation screen that would show a list of *ALL* trigger id's, timed events, macros, globals, etc. that you would then just highlight and drag and drop to the group ID.
Let me know how this sounds for everyone and I'll try to start working on this.
cmhardwick
Posted: November 29 2007 at 22:34 | IP Logged Quote cmhardwick
That sounds great. That way, it's more of just a "display" or "view" option, not in the actual databases. It could also allow (depending on how you did it) for grouping of Trigger, Timed and Macros in to the SAME groups so if you had a set of triggers and macros say that were for your ELK, you could have an ELK group that would have both in there.
Cicero, Enjoying automation!
Posted: November 29 2007 at 22:35 | IP Logged Quote TonyNo
I think I like it.
jeffw_00
Posted: November 30 2007 at 10:11 | IP Logged Quote jeffw_00
the thing I like about it is that I think you're saying you can mix macros, timed events, and triggers in the same group, AND get to the actual item by clicking through the group view.
That would work great for me. Though some people might complain that it adds a step to creating a macro/event/trigger (adding it to the group). Admittedly if the groups were built into the category listing, the group selection would be implicit. But personally, I think it's better to have a way to group items from different categories together.
Posted: November 30 2007 at 10:19 | IP Logged Quote BeachBum
Got my vote.... I definitely have a need. Good suggestion.
bhlonewolf
Posted: November 30 2007 at 10:24 | IP Logged Quote bhlonewolf
Dave -- I like it!
Your idea is certainly the more thorough and in the end, seems like the correct way to do it.   I'm sure it's easier said than done to implement but at the same time would be a huge benefit to organizing these things! Thanks!
Brian
cmhardwick
Posted: November 30 2007 at 21:35 | IP Logged Quote cmhardwick
jeffw_00, I don't think it would be or rather, SHOULD be, a requirement to navigate through the group level to get to the macros, etc. I think that should be ONE way to go, if you want to group items but you should still have the traditional direct access like now.
jeffw_00
Posted: November 30 2007 at 21:49 | IP Logged Quote jeffw_00
cmhardwick - you misunderstood me. I don't disagree w/you.
