         jeffw_00 Super User
           | Posted: December 08 2007 at 17:37 | IP Logged
 I'm trying to set the value returned from an Input box to a global variable SLEEPINCNT - below is my best guess, but it doesn't work, I think because getsystemvar returns a string.
 ph_setglobal_n("SLEEPINCNT",ph_getsystemvar("[INPUTRET]"))
 suggestions?
 thanks!
           | Posted: December 09 2007 at 11:08 | IP Logged
I'm no expert, but will this get you closer..
  ph_setglobal_a("SLEEPINCNT",integer(ph_getsystemvar("INPUTRE T")))
           | Posted: December 09 2007 at 11:51 | IP Logged
You can also try this:
 ph_setglobal_s("SLEENINCNT","[INPUTRET]")
         jeffw_00 Super User
           | Posted: December 09 2007 at 11:52 | IP Logged
beachbum's answer is what I was looking for (missed the integer function in my search of the docs).
 Dave - I'm sure yours will work too, but I'm guessing only because PH is ok treating a 'string' that's only a number as a "number' later on...
 thanks guys
           | Posted: December 09 2007 at 12:36 | IP Logged
No problem.  Keep in mind that ALL variables are actually stored internally as a string (global, local, and temp) and are converted based upon context (in the case of variable substitution) or on-the-fly based upon the ph_get??? function (string, number, time, etc.)
 There are two "set" type of functions.  The default ph_setglobal_s to set a string and ph_setglobal_a to set ANY valid value.  Internally, the ph_setglobal_a will then convert the *any* value to type string and store it in the variable.  When it's time to recall the variable, it will be converted to the appropriate type based upon the ph_get??? function.
         jeffw_00 Super User
           | Posted: December 09 2007 at 12:40 | IP Logged
oh, ok - 8-}
 thanks
