Subject Topic: Garage Door Post ReplyPost New Topic
tbeckman
Posted: February 11 2008 at 18:32 | IP Logged Quote tbeckman
Is anyone using something, (prefer insteon products)to monitor when the garage door is open and send a signal to close it? Thanks.
Back to Top View tbeckman's Profile Search for other posts by tbeckman
jbbtex
Posted: February 11 2008 at 20:56 | IP Logged Quote jbbtex
I did use an ezio 2x4 to monitor and close garage doors, but I now monitor with x10rf door/window sensors via WGL W800RF. I still use the ezio 2x4 to close the door, but I had to build a relay board to interface the ezio to the door contol.
It's currently not working though because last week I had a surge or something that took out my plc, ezio, a toggle linc and two icon dimmers. I have everything back now except the ezio.
Brady
Deano
Posted: February 15 2008 at 11:18 | IP Logged Quote Deano
I use a UM506 wired in parallel with the pushbutton on the wall and set for momentary contact and X10rf door/window to indicate position.
Best if you have auto reverse sensor or you could squish the neighborhood cat by remote operation.
http://www.x10.com/products/x10_um506.htm
Back to Top View Deano's Profile Search for other posts by Deano
