Subject Topic: Vista and Local_Machine keys: phsdm Post ReplyPost New Topic
CV27
Posted: February 11 2008 at 22:35 | IP Logged Quote CV27
I was getting a "ISRESPONDING command failed" message whenever PowerHome (PH) came up under Vista.
With the help of Dave, we found that by registering the SDM wrapper phsdm as a Local_Machine key, versus under Current_User, PH succeeded in communicating with the SDM.
The attached file did it for me. Just change the file type to .reg and Merge; double check also the directory where the phsdm.ocx actually resides.
2008-02-11_222337_phsdm_lm.txt
The mistery is that PH used to work find with Vista without this adjustment. Does anybody have a theory as to why it worked then didn't ?
Dave: answered every email I sent him and spent close to 2 hours working with me on resolving this. Some serious commitment ! THANK YOU.
Back to Top View CV27's Profile Search for other posts by CV27
bhlonewolf
Posted: February 12 2008 at 01:34 | IP Logged Quote bhlonewolf
Did you disable or enable UAC? That would cause the change.
