         Herb Jones Newbie
           | Posted: September 30 2008 at 20:51 | IP Logged
I downloaded and installed as new and had it working and suddenly it is not working. I get a pop up box stating "SmartHome Device Manager ISRESPONDING command failed for Insteon PLC PL2414U.  Attempting to restart controller ..."
 It keeps trying to restart the controller over and over.  I noticed that there is now no icon in the system tray for the SmartHome Timer app.
 I know its something stupid that I have done, but so far I have not been able to fix it.  I sent a "critical error" dump to PH support since it popped up and offered the information.
 This is running on XP Pro service pack 3.
 Thanks in advance for assisting this newb.
  __________________ Herb Jones
 Pleasant View, Tn. 37146
           | Posted: September 30 2008 at 20:54 | IP Logged
Welcome!
 Try this...
 Close down PH, check the task manager to make sure the timer app is closed, then bring PH back up.
         Herb Jones Newbie
           | Posted: September 30 2008 at 21:10 | IP Logged
 I have shut down and restarted PH many times, even completely rebooting the pc but nothing works.  I think the problem is that the timer software is never starting since I never see the icon in the system tray and I used to see it there. I also have the Smarthome Timer software app that I originally started with and it seems to have no trouble talking to the controller.  Just now I loaded the Smarthome timer app and left it running while starting PH but I still get the same message.
 Other ideas?
         mustangcoupe Super User
           | Posted: September 30 2008 at 21:17 | IP Logged
you dont want the "timer app" but the SMD? SDM?  it should be load when PH loads. try and load it manually then load PH.  I beleive it is a directory in the PH directory.
 HA newbie
     PowerHome - UPB - ELK
         Herb Jones Newbie
           | Posted: September 30 2008 at 23:06 | IP Logged
I think I fixed it. I went into windows task manager after shutting down both PH and Smarthome timers and there was still an SDM3.exe running. I killed it and then restarted PH and the SDM3.exe showed back up again and PH now seems to be communicating.
 Go figure.
 Thanks to all for your assistance.
 Herb Jones
           | Posted: October 01 2008 at 21:39 | IP Logged
Glad to hear it got worked out... I had problems back a while ago with a earlier version and this was it... never figured out why though.  but it never happened again.
 HA newbie
         Herb Jones Newbie
           | Posted: October 02 2008 at 08:00 | IP Logged
It actually happened again yesterday evening and the SmartHome app generated a debug report (a piece of which is shown further below)which I emailed to them.
 Not sure why this is happening but then I have just started using/experimenting with PowerHome and insteon. I have had X10 for years but it just became too unreliable in my environment.
 Here is part of the debug.  If anyone wants the whole thing, let me know.
 date/time         : 2008-10-01, 18:36:13, 642ms
 computer name     : SYSTEMAX-1
 user name         : Herb <admin>
 operating system  : Windows XP Service Pack 3 build 2600
 system language   : English
 system up time    : 1 day 21 hours
 program up time   : 20 hours 33 minutes
 processors        : 2x Intel(R) Core(TM)2 Duo CPU E4600 @ 2.40GHz
 physical memory   : 214/2039 MB (free/total)
 free disk space   : (C:) 353.42 GB
 display mode      : 1024x768, 32 bit
 process id        : $176c
 allocated memory  : 48.15 MB
 executable        : sdm3.exe
 exec. date/time   : 2006-06-21 19:01
  version          ;  : 1.1.88.235
 madExcept version : 3.0a
 contact name      : Herb Jones
 contact email     : herbjones@bellsouth.net
 callstack crc     : $a48517d9, $4dff60be, $7ec86833
 exception number  : 1
 exception class   : EAccessViolation
 exception message : Access violation at address 00403ECE in module 'sdm3.exe'. Read of address
 ECF7223C.
           | Posted: October 02 2008 at 11:59 | IP Logged
From that report it looks like SDM crashed.     Try this whatever SDM your using try the other. Go to Program files – PowerHome – SmartHome and click the DOS file your NOT using. See if a different version changes the problem
