         Lenny Senior Member
           | Posted: October 04 2008 at 09:58 | IP Logged
I don't see an installer for the 2.0 remote clients. Did I overlook them?
 I tried just copying over the files, CC was unable to locate a DLL... Didn't want to install PH completly on remote computer to register DLLs.
  Edited by Lenny - October 04 2008 at 09:58
         Lenny Senior Member
           | Posted: October 11 2008 at 20:35 | IP Logged
Anyone else experiencing this since their upgrade to PH2? Control Center works within PowerHome... but the RCC client crashes even if you copy all the DLL's it can't find to the same directory as the RCC executable.
 RCC doesn't even work on the computer running PH...
 For me it's completely broken.
  Edited by Lenny - October 11 2008 at 21:28
           | Posted: October 11 2008 at 22:58 | IP Logged
My old DS works, but not the CC.
         Lenny Senior Member
           | Posted: October 11 2008 at 23:46 | IP Logged
Ok, It's not just me then.
 Yeah, Remote DS seems to work, however the filter seems broke now… The filter says Filter is OK when you verify… but when you click ok and it tries to apply the filter you get error “expression is not valid” but the filter works… also the integrated device status shows a location pulldown and the current Remote DS doesn’t have that.
 I'm sure Dave is building a list of fixes... It would be nice if there was a someplace with a list known active bugs.
 Thanks for the Reply.
         Lenny Senior Member
           | Posted: October 12 2008 at 21:39 | IP Logged
Dave said "both the Remote CC and Remote DS are currently being updated.  The Remote CC will also be updated to support the new global variable object type and the Remote DS will have the filter fixed and the new location dropdown.  He will be releasing these new versions along with the 2.0.1 version to fix the current round of bugs."
