edtude Groupie
Posted: October 26 2008 at 16:25 | IP Logged
Since upgrading and installing Powerhome on a newer machine, the application is "locking up" and I have to close it and restart it, several times I even had to restart the PC because after the app restarted it it could not see the database. Any help?
edtude Groupie
Posted: November 03 2008 at 14:51 | IP Logged
Still having this problem, I am going to rebuild the entire database because i noticed that when I am in Insteon Explorer if I download all IDs to the PLM only like 7 of my 19 devices are downloaded yet all of them show in the lists.
Posted: November 03 2008 at 15:48 | IP Logged
You should only have to download min. What OS and are you using a PLC. Also where does it lockup in the process.
edtude Groupie
Posted: November 03 2008 at 16:03 | IP Logged
It locks up during normal operation, running XP Service Pack 2 which is what I had on the last box. the only reason I made mention of the database issue is because for what ever reason it seems like something in the database is missing. I am using a 2414U PLC I guess.
Posted: November 03 2008 at 16:51 | IP Logged
Do you backup your database. When you lockup does that mean PH won’t open any windows like PH Explorer or do you mean the devices stop responding to commands.
edtude Groupie
Posted: November 03 2008 at 18:18 | IP Logged
The Powerhome application locks up on the PC, I just end up with a white screen whatever window was open is no longer there and the only way to clear it up is to exit the app whatever way I can. Never have backed up database so that is why I am going to rebuild it.
Posted: November 03 2008 at 18:25 | IP Logged
Almost sounds like a Windows problem. Can’t say I’ve heard of anyone having that type of lockup. I assume you are getting the non-responding message when you go to terminate it. If you are going to rebuild the database why not uninstall PH and reinstall.
