           | Posted: November 26 2008 at 22:57 | IP Logged
All,
 Well its finally here.  Release 2.1 of PowerHome is now available.  Check it out on the download page.  The only thing missing right now is the updated manual.  Im a quarter of the way through on updating but didnt want to hold up the release while waiting on it.  As soon as its finished, I'll upload it.
 Also included in the 2.1 release are the new Remote Clients.  They are also available on the download page as a separate install.  Ive also created ANSI versions of the Remote Clients on the download page (these versions run on all versions of Windows from 95 up).
 Also included is a zip file (phupg_all.zip) which includes upgrade files for all public versions of PowerHome.
 Anyways, let me know if anyone has any problems and Happy Thanksgiving.
           | Posted: November 27 2008 at 09:11 | IP Logged
Thanks Dave!
 In addition to the normal upgrade steps, don't forget to copy over any plugin ini files!
           | Posted: November 27 2008 at 09:29 | IP Logged
Looks like the Help file still needs to be updated, too (ph_setforegroundwindow1, ph_runasuser, ph_show).
 So far, so good!
           | Posted: November 27 2008 at 11:40 | IP Logged
Interesting note.. On my Vista system I could not rename Powerhome in the program files. Had to go into Safe Mode. Said it was being used. Don’t know by whom. Otherwise went clean on XP and Vista.
 Happy Turkey Day.
         raven77 Groupie
           | Posted: November 28 2008 at 09:16 | IP Logged
So how do we use this?
 "Added new /ph-cgi/eval function. Takes a single parameter called formula. Evaluates the formula and returns the result as text without any HTML."
 Sounds interesting...
         MrGibbage Super User
           | Posted: November 28 2008 at 09:42 | IP Logged
I just upgrade from 1.03.4.11.  I think I followed the stepps correctly, renamed the old directory, installed the new version, did the two-step database upgrade (By the way, you could make it a little easier to find PHUPG10396.EXE) and started up PowerHome.  Everything looks good.  Initial thoughts/concerns.  The device Status screen doesn't show all of my insteon devices any more--just the groups.  Is that the way it's supposed to work?  I liked the old way better when I could see each individual light.  Or am I just missing something?  Other than that, so far, so good.
 One other note, in the old users manual, it states that there are sample psp pages in the web folder, but I don't have any in my installation.  I'm sure I didn't delete them, and I checked every version/folder I've had since I first installed PH two years ago.  Am I missing something here too?
           | Posted: November 28 2008 at 11:05 | IP Logged
Is “All Locations” selected in the Device Status screen? Or maybe you have a filter set.
           | Posted: November 28 2008 at 11:22 | IP Logged
Yeah, "* All Locations *" is set, and I went into the filter and it seems to be blank, so I don't think that is it either.
           | Posted: November 28 2008 at 11:35 | IP Logged
Do they show in the Insteon Explorer screen?
           | Posted: November 28 2008 at 11:50 | IP Logged
Yep, all there.  Strange huh?  Control Center only lists insteon groups, no singe devices.  But in the insteon explorer, I can see both my groups and my devices.
           | Posted: November 28 2008 at 12:15 | IP Logged
Raven: Something like /ph-cgi/eval?formula=now()
           | Posted: November 28 2008 at 12:17 | IP Logged
In my last post, I said "Control Center" where I meant to say "Device Status".  Sorry.
           | Posted: November 28 2008 at 12:22 | IP Logged
Here's a screenshot
           | Posted: November 28 2008 at 12:27 | IP Logged
Check to make sure that those are not set up as Don't Display. This is in the Insteon Devices screen.
  Edited by TonyNo - November 28 2008 at 12:27
           | Posted: November 28 2008 at 12:31 | IP Logged
If I were to make a wild guess I’d say something went wrong in the DB update.
           | Posted: November 28 2008 at 12:33 | IP Logged
They are not.
           | Posted: November 28 2008 at 12:34 | IP Logged
       | If I were to make a wild guess I’d say something went wrong in the DB update. |
 That's what I think, but there were no error messages at all.  Everything looked great.
           | Posted: November 28 2008 at 14:39 | IP Logged
Well, you won't believe it, but I fixed it by "sorting" the list.  yeah.  All I did was press the "Sort" button, added the "type" field, and applied it and now everything is there.  Go figure.
  Edited by MrGibbage - November 28 2008 at 14:40
         edtude Groupie
           | Posted: November 29 2008 at 11:21 | IP Logged
MrGibbage wrote:
       | Well, you won't believe it, but I fixed it by "sorting" the list.  yeah.  All I did was press the "Sort" button, added the "type" field, and applied it and now everything is there.  Go figure. |
 Database's can be quirky sometimes and simple manipulation goes a long way to clean things up 'mysteriously'  On some of the systems I work on -real work not Home Automation stuff :)-- we often run into situations where it looks like everything is in the DB properly, but for whatever reason the device just won't work.  Before we go to a lot of work to delete and re-enter the device and all associated devices, cause you know how associations are, we simply dirty a bit, meaning check a box that will actually not change anything and then save...it is amazing how many things fix themselves with that method.
         Viper Groupie
           | Posted: November 30 2008 at 11:17 | IP Logged
 Overall, I'm impressed.  I like the status bar and I can see you've addressed all the things I ran into in 2.0.0.
 I had some problems with the upgrade and it might have been due to when I captured my pwrhome.ini and pwrhome.db file.  I like to uninstall the previous version of Powerhome just to keep things clean.  It appears my pwrhome.ini ended up without the pointer to the pwrhome.db file and it also was missing a WEBSERVERDIRECTORY (or something like that) entry.  I hand created those and then all was well.
 The last thing is not causing a problem, other than performance.  When PowerHome issues an Insteon Group command it now sends the Insteon Group command followed by Group Cleanups to each of the devices in the group.  However, for each device, it is sending the Group Cleanup, receiving an ACK, sending the Group Cleanup, receiving an ACK, sending the Group Cleanup, receiving an ACK, then goes on to the next device and does the same three repetition dance step with the next device.  So for my BEDTIME group, it took 2 minutes and 42 seconds to complete, when it could have completed in 54 seconds.  Again, not a functional problem, just a bit slower than it could be.
 Thanks for the great job Dave!
 Tom
  Edited by Viper - November 30 2008 at 11:31
