Subject Topic: Weather Program Post ReplyPost New Topic
Posted: August 30 2003 at 20:53 | IP Logged Quote TonyNo
I just happened upon a nifty weather program called WeatherWatcher. The cool part, besides being free (with no ads or spyware), is that it generates dynamic HTML that you can tap into!
Look here.... http://207.218.206.9/~singerscreations.com/AboutWeatherWatcher.html
theowl
Posted: June 12 2006 at 17:00 | IP Logged Quote theowl
Tony, this sounds interesting. I did a forum search on weather watcher, but did not see much. Could you give me an code example of how you have taken advantage of this program?
Back to Top View theowl's Profile Search for other posts by theowl
Posted: June 12 2006 at 20:08 | IP Logged Quote TonyNo
No code, I just shared/created an alias for one of the WW's folders in my web server (Weather Watcher\Skins\Forecasts\Splendid). Too easy!
theowl
Posted: June 13 2006 at 09:30 | IP Logged Quote theowl
Sweet! I'll try this after I get my morning macro set up the way I want.
theowl
Posted: July 02 2006 at 00:05 | IP Logged Quote theowl
Hey Tony...Thanks for sharing this info.
Here's what I have done to put Weather Watcher to use.
First, I have Weather Watcher check for the weather every 15 minutes. Then, export it automatically using the following template...
The following forecast was updated [Updated datetime]
[SEVERE ALERT]
[Location] the current condition is [Condition]
The Temperature is [Temp] but it feels Like [Feels].
Your Extended Forecast is
[DETAILED LOOP COUNT=2]
[TEMPLATE]
    . . .[DETAILED DAY]
    [DETAILED FORECAST]
[/TEMPLATE]
[/DETAILED LOOP]
Second, I use the WWA2 codes to check for warnings every 15 minutes. If a warning/watch comes in, I have it read the header information via TTS, then call my Weather Macro which just does a ph_readfile("c:\Weather.txt") file from Weather Watcher.
Works awesome, plus I can call the weather macro anytime I want with one of my remotes and know the file will be up to date.
Posted: July 02 2006 at 00:23 | IP Logged Quote TonyNo
Good going! Glad to help.
