Subject Topic: Apache and Web Center Conflict Post ReplyPost New Topic
cruelkix
Posted: January 22 2009 at 15:00 | IP Logged Quote cruelkix
I am using my web server as my home automation server. To host my Web page I am using apache. When I start the services for apache, it conflicts with the PH Web Center. I cant have both running at the same time. This is completely my fault I'm sure as I am a total n00b. Can anyone help me out here and let me know either how to set up PH or Apache so that I can have both running at the same time?
Cruelkix
Back to Top View cruelkix's Profile Search for other posts by cruelkix
onhiatus
Posted: January 22 2009 at 18:09 | IP Logged Quote onhiatus
My guess is they're both fighting over the default port (80). You'll need to configure one of them to use an unused port - 8080 is often used for multiple http servers on the same machine.
You'd then access the server by specifying the port in the url. Something like http://yourserver:8080/
Good luck, Tony
cruelkix
Posted: January 23 2009 at 12:13 | IP Logged Quote cruelkix
Good luck, Tony
Thats what I was thinking but my brain never worked it out. Thanks for the advice I'll give it a try wen I get a few minutes..... Leaving for vegas tonight so I don't think I'll have time today.
Thanks again,
Craig
cruelkix
Posted: January 29 2009 at 18:36 | IP Logged Quote cruelkix
Just as an Update: Onhiatus was very right. For some reason 8080 did not work but 81 did.
I can now control my lights form anywhere in the world (that has wifi.....)
