Subject Topic: tts time every hour Post ReplyPost New Topic
mustangcoupe
Posted: March 03 2004 at 20:32 | IP Logged Quote mustangcoupe
I am trying to use the announce hour macro from the sample database... easy I figured... BUT it dosnt "say" anything.  If I use the formula builder and verify each part of the formula it is correct... until the TTS line, it dosnt say anything, almost as if there is nothing stored in the variable
Todd Hannemann
HA newbie
   PowerHome - UPB - ELK
Posted: March 03 2004 at 21:30 | IP Logged Quote dhoward
Todd,
Did you use the formula exactly as it was in the sample?  If so, it won't work as I had it temporarily disabled since it was getting on my better half's nerves.
The very first line of the macro is "Jump 999" which will essentially cause the macro to jump to line 999 which is waaaayyy after the end of the macro so it just does nothing.  If its still there, just delete the first line .
If thats not the problem, let me know and we'll work it out.  Another way to test and verify is to change the last line from TTS to Message Box with TTS.  That way you can see exactly what it's trying to speak.
Posted: March 03 2004 at 22:08 | IP Logged Quote TonyNo
Here is my hourly announcement code called by an hourly trigger...
[TEMP1] | hour( now() )
[TEMP1] | if( [TEMP1] = 0, 12, [TEMP1] )
[TEMP1] | if( [TEMP1] > 12, [TEMP1] - 12, [TEMP1] )
TTS     | string( [TEMP1] )
The system saying "zero" drove me nuts for a bit! I also play a grandfather clock chime just before the hour is announced. I always liked that sound!
mustangcoupe
Posted: March 04 2004 at 21:37 | IP Logged Quote mustangcoupe
where did you get the chimes... that is actually what I wanted in the first place??? do you play a diffrent chime for every hour or just the same chime all day?
Todd Hannemann
HA newbie
Posted: March 04 2004 at 22:46 | IP Logged Quote TonyNo
I found the chimes by searching for wav's via Google.
My macro plays a complete chime (8 notes) on the hour, then, announces the hour number. On the halves, I just use a singe note chime.
Complete Chime: http://tonyno.ods.org/gfclock.wav
Single Note: http://tonyno.ods.org/gfclocksingle.wav
Maybe I'll change it up a bit and make it a cuckoo clock!
mustangcoupe
Posted: March 05 2004 at 16:51 | IP Logged Quote mustangcoupe
I dont think that I could get away with that.....
Todd Hannemann
HA newbie
